  • Replies 146
Did anyone else but tats and myself see the little fiat bambino. Complete with half cage and a turbo strapped to the side of the little 2 cylinder engine?
Was the coolest car of the show for me
I took a couple of photos. I might post them up but I had a smear on the lens which wasn't apparent until I looked on the computer.
when I got home from Wheels on Sunday I heard water frying on the engine :(
Checked it out and it seemed to be comming from the back of the block where I couldn't see or get to.
I got REAL concerned...... you'd understand if you knew my history with this GTR.
Did some further checking on SAU to see what it could be. Opinions - a hose (sigh of relief)
It turns out one of my Turbo water lines that goes around the back had a pin prick of a hole but opend up under pressure.
and you cant get to it without taking the inlet manifold off and other stuff around that area.
1 x 4" hose $8
2 x hose clamps $7
Labour $330 - Ouch!
Peace of mind - PRICELESS!
yeah, both Andrew Mark stopped like champions!
Turned out that the positive battery cable past too close the extractors, melted the insulation and earthed it out.1 new battery and a relocate for the cable and I was running again. Interestingly, the first battery was still
I did.... I think I might have missed Zeb's Supra out, but took it from that end looking down when all the cars were still there. I'll upload it when I get home from work.
alright thanks heaps, i just completely had a brain fart and forgot.
  • 3 weeks later...
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
