  • Replies 86
do you have the drivers side, power window buttons 'surround pannel'?
COMPLETE TURBO *SOLD*
STARTER MOTOR
MASTER CYLINDER/BRAKE BOOSTER
IGNITOR MODULE *SOLD*
ECU
CASTOR RODS (PAIR)
FRONT LEFT LOWER CONTROL ARM
AIR CON CONDENSOR
HVAC FAN BLOWER
HVAC UNIT (HEATER CORE, NO LEAKS)
PEDAL SET
PETROL TANK
GLOVE BOX
DASH PAD
CENTRE CONSOLE WITH LID
R + L DOOR TRIM
R DOOR
R MIRROR
STEERING COLUMN COVER
BOOT/PETROL LID RELEASE
BONNET RELEASE
AERIAL *SOLD*
FUEL PUMP
OUTER PILLAR TRIM
FRONT HUBS *SOLD*
PRESSURE PLATE
ENGINE WIRING
WIRING LOOM
POWER STEERING RACK
STEERING COLUMN
REAR ‘SKYLINE’ SIGN
AFM *SOLD*
TOW HOOK
ALL SEATS
R REAR QTR PANEL
L REAR QTR WINDOW
CARPET
FRONT WIPER MOTOR
REAR WINDOW
SIDE INDICATORS
BOOT *SOLD*
SPOILER
DIFF
L WINDOW MOTOR
INTERIOR LIGHTS
INTERIOR PANELS
OTHER SMALLER PARTS
*No other parts are available*
Jetgts your PM box is full - just letting u know that I deposited funds for the 3 Nismo caps. And a reminder if u come across the following for r33 series 1:
- glovebox
- ashtray
- cig lighter
- back right inner boot lining trim
to let me know.
- glovebox
- ashtray
- cig lighter
to let me know.
Im pretty sure its not full? I'm getting pm's from others... I don't know about the 3 nismo caps?? What r u talking about? I'll get onto sending the glovebox, ash tray and cig lighter though...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
