hello all, i have a dilemma with cracks on the inside and outside of a recently purchased rebuilt t3 hi flowed turbo for a r33 gtst... the bloke i bought it off claims he didnt know about the cracks and says he got it built at turbologic in portkembla and its never been used as of yet..
In someones knowledgable opinion is the housing completly screwed or can i bolt this up to my r33 and hope for the best?
if this turbo is indeed screwed why would turbo logic build it and give it back to the customer?
theres a big crack that leads to a hole, but the hole is right where it opens up anyway so would this be a problem?
Anyones advice,experience or info would be greatly appreciated thankyou :)
https://www.sau.com.au/forums/topic/393716-cracks-inside-rebuilt-turbo/
pretty sure rebuilt means they use old housings and just put in a new turbine / wheel so it could well have been cracked before and he just got it rebuilt but was to scared to use it. I wouldent use it, does he have reciepts for rebuild? if not then assume its not rebuilt either.
hey, iv got all the old parts that were on the turbo before it was apparently rebuilt and it also looks like the whole turbo and housing has been acid dipped or somethin. the photos were taken inside the exhaust side of the turbo and theres no soot or anything..
I never thought to even check for cracks only check the fins for movement etc i feel like an idiot!!..
i just thought that if the housing was shagged why would the builder complete the job? i heard this turbologic place was good.......
I have seen plenty of cracked turbo housings, its fairly common on the xr6 gt35 rears and usually around the wastegate. I doubt it would cause you problems but I wouldn't want it inside my turbo. >_<
I won't worry too much about the hair cracks around the wastegate hole. But the split inside the turbine housing is no good. I've seen few happened to some old VLT T3 turbos, this turbo would need a new turbine housing.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
