soultz Posted March 8, 2012 Share Posted March 8, 2012 ive got a exhaust thats it, plus the coil packs. the spark plugs are brand new, gapped to 0.8mm Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267024 Share on other sites More sharing options...
Rolls Posted March 8, 2012 Share Posted March 8, 2012 There you go chances are it is running more boost than stock, eg R&R what number does it hit on the stock gauge? Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267033 Share on other sites More sharing options...
arrydjay Posted March 8, 2012 Author Share Posted March 8, 2012 Could the o2 sensor make it run rich and miss? Mine was getting really bad fuel economy and I read on here that the o2 sensor should be the first thing to change. I disconnected the old one and started the car and went for a drive and it runs exactly the same....so im guessing it was cactus. Havnt had a chance to drive it yet with the new sensor. Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267045 Share on other sites More sharing options...
Rolls Posted March 8, 2012 Share Posted March 8, 2012 o2 sensor has nothing to do with the on load fueling only around town. It is possible it is the cause of poor fuel economy though. Get a consult cable and find out what sensors have failed. Actually an air leak will make the car run rich hence rich misfire, it will also cause bad fuel economy. Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267059 Share on other sites More sharing options...
arrydjay Posted March 8, 2012 Author Share Posted March 8, 2012 What is a consult cable and where do I get one? Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267135 Share on other sites More sharing options...
Rolls Posted March 8, 2012 Share Posted March 8, 2012 Go see a workshop, or search the forums. Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267160 Share on other sites More sharing options...
soultz Posted March 8, 2012 Share Posted March 8, 2012 boost gauge goes to 7 psi max. dont go over that. holds boost too... Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267163 Share on other sites More sharing options...
Rolls Posted March 8, 2012 Share Posted March 8, 2012 (edited) boost gauge goes to 7 psi max. dont go over that. holds boost too... The gauge isn't in psi, it is in mm of mercury. What does it read in that? If it is 7x10mmHg it is 14psi which absolutely explains the misfire. Edited March 8, 2012 by Rolls Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267177 Share on other sites More sharing options...
soultz Posted March 8, 2012 Share Posted March 8, 2012 i dont have a stock gauge, ive got a gtr cluster Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267180 Share on other sites More sharing options...
soultz Posted March 8, 2012 Share Posted March 8, 2012 i manually fitted a boost gauge so i could see what boost i was running, i achieved 7 by doin the high boost mod form the to do section on here, and that made it 7 psi, i thought that could have been the problem so i reversed what i did today ,and it still does the same Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267181 Share on other sites More sharing options...
Rolls Posted March 8, 2012 Share Posted March 8, 2012 that is also in mmHg afaik Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267182 Share on other sites More sharing options...
soultz Posted March 8, 2012 Share Posted March 8, 2012 my cluster has engine temp, oil pressure, tacho and speedo thats it. the ggauge i bought has psi/vaccum level and it says 7 on there Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267186 Share on other sites More sharing options...
soultz Posted March 8, 2012 Share Posted March 8, 2012 and fuel level sorry ^^ Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267188 Share on other sites More sharing options...
Rolls Posted March 8, 2012 Share Posted March 8, 2012 In that case I suspect air leak, get a smoke test done at a workshop, and get them to check all error codes with a consult cable. Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267209 Share on other sites More sharing options...
soultz Posted March 8, 2012 Share Posted March 8, 2012 Can do. I was going to put it on the dyno on Tuesday and see air fuel ratios... Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6267218 Share on other sites More sharing options...
arrydjay Posted March 11, 2012 Author Share Posted March 11, 2012 ok.....so it seemed like the problem went away but it is now back... I tried changing the plugs out too some .8 gapped copper plugs but it is still there. I have found that the problem is worse when going around big sweeping corners or up hills...weird.. Ive also noticed it isnt only up high in the rev range but also down low...like the moment I jump on the trottle it starts to cut... Next step is to re solder the AFM and clean with contact cleaner Any ideas what else I should try? Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6269974 Share on other sites More sharing options...
Rolls Posted March 11, 2012 Share Posted March 11, 2012 Consult cable. Take it to a workshop. Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6269977 Share on other sites More sharing options...
arrydjay Posted March 11, 2012 Author Share Posted March 11, 2012 I checked the fault codes and it was just flashing 55 which means no errors... A consult cable couldnt tell me anything more could it? Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6270027 Share on other sites More sharing options...
arrydjay Posted March 11, 2012 Author Share Posted March 11, 2012 its also gets heaps worse if I turn the boost up at all... Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6270331 Share on other sites More sharing options...
DVS JEZ Posted March 11, 2012 Share Posted March 11, 2012 New coilpacks or running out of fuel. Link to comment https://www.sau.com.au/forums/topic/393964-r33-gtst-cutting-out-under-load/page/2/#findComment-6270341 Share on other sites More sharing options...
