  • Replies 117
Posted Images
The oil feeding line supplied with the turbo looks like its gonna be a bit long, will this matter or should it be trimmed up? If so, how do i got about trimming it, because the fittings on each end dont look like they come off easily...
And just to confirm its a 24mm socket/spanner need for the water line banjo bolts isn't it?
Edited by Mitcho_7
Well after a really long day, turbo is in along with metal intake. At the moment the bov return and bov are bloked off, because I could not get the hose to go on the bung of the intake and the metal bov return pipe without kinking or touching the exhaust manifold. So a trip to enzed on Monday for some rubber hose in the right diameter an hopefully there wont be anything else major crop up.
Hey Mitch I ended up getting some really nice hose that still touches the manifold but is holding up perfectly
Got it from A place on kembla st in fyshwick they are on the right I forget the name of them
The guys at enzed didn't have anything that could handle the heat
Ok, will check it out.
Anyone know why I can now hear a bubbling sound while im driving thats sounds like its coming from in the dash/ under hood?
A shit tonne of coolant came out of the water lines of the turbo, so once they were bolted back up, I poured coolant and water into the top of the radiator. I'm thinking the bubbling has something to do with the way I have done that...
Bleed hole on inlet plenum, 10mm spanner.
Have the car facing uphill and open (release pressure first!)
Bubbles of air trapped in the head come out,
top up from the radiator and see the coolant come out of the hole,
plug it back up,
run the motor for a minute or two,
Repeat untill all air is gone.
Ps. buy good tools, they are good as gold and will last decades, i have some of my grandfathers tools, spanners in the 50'S were made of good steel.
Dont buy shit tools, they will strip bolts and bust your knuckles and you will wish you had just borrowed dads sidchrome set.
also make sure your heater is on when you are bleeding the system as there could be some air in there too. Good tools are worth their weight in gold. I still have all my tools from my apprenticeship except ones that have been 'borrowed' or ones i misused.
Can I assume that if the coolant level in the radiator hasn't dropped between now and when I did this thismorning that most air bubbles are out?
When I first checked it this morning there was a lot less in there than what was put in originally after the turbo install. Im assuming this is because it's a closed system with the bolt ad radiator cap on and all the air that was trapped in the head etc making it seem like the coolant was full but overnight the air has just traveled to the top of the radiator?
got my nistune ecu back today from Matt and exhaust temp light and FICD issues have been sorted!
Also managed to ghetto up a temporary bov return line until the 1 1/8 inch silicone hose turns up then ill use it and wrap the area that touches the exhaust manifold in some heat wrap.
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
