This guide is based on the original instructions that craz0 kindly sent me.
I used Bilstein shocks and kept standard springs.
Tools:
Pair of spring compressors
Socket set
Pipe for extra leverage (see below)
Small shifter spanner
14mm ring/open end spanner
Trolley jack, stands
Steps:
1. Remove seats, parcel shelf
2. Jack up car, put on stands
3. Remove struts
4. Disassemble then reassemble struts around new shocks
5. Refit to car
1. Remove rear seat & parcel shelf
The rear seats and parcel shelf have to be removed to allow access to the strut tops. The seat is held in by bolts and clips - click here for a step by step guide on removing the seat. I used a screwdriver as a lever to pop the clips off, which seemed to work well.
Now the parcel shelf. There should be some bolts holding the baby seat anchor points - remove those. The plastic cover that hides the rear window wiper motor etc needs to be removed as well. Wriggle it around a bit and pull it towards you to remove it. To remove the shelf itself you need to press the two ends as the plastic quarter interior trims are keyed into the parcel shelf. Just watch those, it took me ages to work it out the first time! And don't be afraid to bend the shelf a little bit, its fairly flexible :D
I raised the whole back end (ie didn't do one side at a time). I think is probably the easiest way, the car is much more stable. Make sure you put the stands in a structurally sound position, don't want to bend anything. Never work under a jacked up car.
3. Remove strut(s)
The strut it held in place by 2 nuts on the pillow mounts (accessed from beneath the parcel shelf), and the eye bolt at the bottom of the suspension strut, underneath the car.
People have used various methods for removing the strut. The way I did it worked well: I unscrewed the eye bolt (17mm) first then the two pillow mount nuts (12mm). The eye bolt was tight - I needed to put a pipe on the end of the socket wrench for extra leverage (but then again I'm a bit of a wimp :(). The strut should now be supported by the lower lug. I then positioned the jack just below the bottom of the strut, to catch the strut when I knocked it off the lug. With a few small taps the strut was off the lug and sitting on the jack. Now just release the jack and watch your strut glide slowly to the ground :) (alternatively just catch it - I wasn't sure how much it weighed so thought the jack was a much safer method).
4. Disassemble then reassemble strut around new shocks
Now you will need spring compressors (I picked some up from Supercheap for $32) to compress the springs so you can undo the top centre pillow mount nut. Make sure you do it evenly on each side of the spring when you are compressing and uncompressing, don't do it one side at a time - put them both on and do about 8 to 10 turns on one side then the same on the other side then back to first side and so on and so forth.
After you compress the springs get a small shifter and a 14mm spanner (ring or open end). The centre shaft that the nut screws down on has two flat sides on it above the nut. Put the shifter on that and the spanner on the nut. Undo it most of the way, then check to see if you can unscrew it with your fingers. If you can't, you need to compress the springs more (or risk serious injury when the nut shoots off at great force).
Once you have the nut off, you can now remove the pillow mount (you have to re-use your original pillow mount with the Bilstein shocks). Take careful note of the order and way up everything is as you pull the strut apart. Take the spring off with the spring compressors still on it, now remove the bumper and bump plate (you have to reuse these as well) then remove the shock cover which has the bump stop built into it up the top. If you buy Bilsteins I recommend getting the new shock covers with bump stop built from Nissan (expensive but worth it). I didn't and I had to cut the bump stop off the original, and try and attach it to the universal shock cover I got - its a messy job.
Rebuild the strut around your new shock absorber - reverse the above steps. When your new centre nut is screwed on, uncompress the springs. Note that the centre net is self locking and can't be reused. If you get new (lower) springs at the same time, you will most likely not have to compress the spring to get it back on, but if you use your original springs like I did you will have to compress them so you can put your pillow mount back on (just leave them compressed from when you took them off).
5. Refit to car
I lubed up the lower lug and eye of the shock with vaseline, I'm sure any type of grease would be fine, that's just what I had handy. This makes it easier for the eye of the shock to slide on, and also hopefully prevents squeaking in the future. I found it easiest to reverse the process used to remove the strut. Put the top pillow mount studs in their holes (this requires a bit of jiggling around) and slide the eye of the strut onto the lower lug. You might need to push down on a control arm or the brake discs or something so it will line up and slide on. Now that its sitting on the lug, do up the pillow mount nuts. When you removed the two pillow mount nuts you would have noticed they weren't particularly tight. This is because the studs are fairly weak - so make sure when you put the nuts back on you don't use too much force. Then do the eye bolt. Make it as tight as you can - use the pipe for extra leverage.
You're done! Jack up the car again to take pressure off the stands, remove the stands, release jack and lower car, refit parcel shelf/seat. I'm leaving my seat out for a bit - I'm sick of taking passengers ;)
Get a wheel alignment as soon as possible.
Hope this helps someone, if I've missed anything just ask!
Greg
https://www.sau.com.au/forums/topic/39405-r33-diy-install-rear-shocks/
thanks man....i should have taken some pics but my digicam batteries were flat and i didn't want to wait for them to charge.
fronts are probably going to be done before the end of the year, stockies are still in pretty good nick so when they start to deteriorate i'll replace them :)
thanks for your help :D
well I was about to do a guide as well but hey, guess you guys beat me to it hahaha
I'll just add to this one then
with some pictures
Pic 1
After removing the rear seats and parcel shelve loosened the two bolts holding the suspension, circled RED, if the bracket marked with the BLUE lines gets in the way just take it off
if you are uncomfortable with working in the car while its on the stands then undo the bolts completely, just remember to catch the shocks when it falls down later after you undo the bottom bolt (circled red at pic 3)
Pic 2
this pic is just to show when you jack up the car (preferably with a hydraulic jack), use a point under the dif and place the stands under the swaybars. Dont really have a pic of the stand mounts and I did it wrong in the pics (which was actually quite dangerous hahahah)
Pic 3
undo the bolt holding the shocks to the lug(RED) and if you've undone the top bolts then just be prepared. Tap the shocks slightly to remove it from the lower lug.
Pic 4
use spring compressor on standard springs before you attempt to remove them
(Surrounded in blue) and undo the top centre pillow mount nut (RED).
I was simply changing to King Spring Lows so I didnt have to rebuild the shocks or anything, but Greg has covered how to install the bilsteins which are probably a lot better than my worned shocks. oh btw if you want to know the condition of your shocks, try compressing it with your arms(after you remove the springs) and count how long it takes to undo itself, good shocks usually take about 2 secs, near dead ones (like mine) takes freakin ages.
lowered springs dont need compressing, just slide them in and tighten the top centre pillow mount nut just enough.
Pic 5
I thought you needed to undo some of the bolts of the suspension arm to place the shocks back in, but I guess I was wrong. I didnt bother to try so I took off these bolts(RED) before placing my shocks back.
  • 5 years later...
  • 3 years later...
Hi guys. It's my first time trying to change my shocks - replacing the stock ones with some tein superstreets on a R33 gtst.
I've removed the back seats, but have problems with the parcel shelf. But the real issue is i noticed a metal casing covering the middle of the top of the rear strut. I can access the two size 12 nuts, but am wondering what is the deal with the metal case.
Do i need to access the middle part of the strut or can i go ahead and just leave it and loosen the two size 12 and continue with the replacement?
I'm guessing it's the same as the 34 - if so the metal cup will come off once you loosen the two nuts. I'm not sure what the point of it is, I've left mine off with the coilovers.
  • Like 1
update: rear shocks all done. turns out it was relatively simple. the biggest problem was a mad tight bolt over the eye lug, followed by not being able to remove the parcel shelf.
thanks for the tutorial and the replies everyone!
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
