Not much to it really.
1x GTS-4 RB20 (4wd) with a spun bearing. Everything else is good and was running fine.
Turbo, injectors, coils, manifolds, fuel rail, fuel reg etc etc
1x R32 RB20 (rwd) engine with clutch. Was bought to change over but the blocks have a different sump bolt pattern and was useless. Came out of a running car. Its complete without manifolds.
Make an offer on anything and everything. I am home all week so I can strip and send stuff pretty much same day.
If it is not gone by the weekend I am pulling them apart for scrap.
Cheers,
Ariel
https://www.sau.com.au/forums/topic/394753-stripping-2x-rb20s/
calsonic, consider it done if you want it. I have been offered $300 but that was last night from a friend of a friend and we know they go nowhere fast. make an offer
No worries Scott. If the engines are sold by the weekend.You can come and get anything you want off them. Might be easier to take the complete head.
Edited by ISL33P
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
