Hi,
I have some DBA 4000 rotors, hel braided brake lines and some remsa pads i need installed.
What workshops in perth do you trust and have had good experiences with to do this?
Thanks
Rob
Do them yourself? Easy as hell, rotors take less than 10 minutes per corner, if you're doing rotors then pads take an additional 2 minutes per corner, and HEL braided lines are very very easy as well, although you will need to bleed your system. Could do all four corners in less than 2 hours, allowing time for messing around if it's your first time. Better than paying some workshop $200-$300 to do it all.
yer but if he doesn't know what he's doing, $300 is cheaper than an accident. If you're new to this have a go at doing your rotors and pads but dont attempt the hoses/bleeding unless you're being supervised by someone who can help you do the job correctly.
Edited by BANGN
Thanks for the replies guys.
I have changed pads and bled the system before. Just unsure on doing the lines and rotors.
Dont want to get anything wrong, so i'll just take it to a workshop.
rotors are pretty easy, remove the caliper, the rotors are floating so they should pull off, if not there is a couple of small threaded holes on the hat of the rotor, put in a metric bolt to size, pretty sure they're a 10mm headed bolt. Wind the bolt in and it will pop the rotor off if its seized on. Just make sure the mounting surface is clean before you put your new rotor on, or you could have pulsations under braking. Dont forget to spray your rotors with some brake cleaner and wipe them to remove the film they use to protect the rotors from rusting in the box. The slotted rotors are directional too, so check you have them on the right way.
hoses are pretty easy, there will be a U shaped clip holding the line to the strut assembly which you just pull out, then use the correct tool to undo the fittings off the caliper for the hose and off the car. You need a pipe spanner like this.
using this tool will greatly reduce the chance of rounding those soft fittings, unfortunately it happens a lot because people smash on crappy open enders.
Just do them up as tight as you pulled them off and move the steering side to side to make sure its not stressing/twisting the new hose.
Then bleed the system starting from the LHR wheel, then RHR, LHF then the RHF. You Start from the furtherest wheel from the master cyl and work your way to the drivers wheel.
Edited by BANGN
This was very helpful, thanks.
I have read a couple of tutorials, i'll just give it a go myself and take my time.
Are you LOLing becasue you would have this job done long before you finish your first can of Jacks? lol
I do not drink Jacks and i dont drink on the job :rolleyes: BUT this would be quicker to do then a 33 clutch job :thumbsup:
*smacks forehead*
Your a the sphincter of the universe drinker?
You catch my drift though :)
Mayuri Krab, how much did that cost you, want to get my brakes upgraded so need to know how much it would be on average, as i've had most of my engine work done at hyperdrive i know i can trust Andrew to get the job done properly.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
