Hi peeps,
Wondering if someone out there with 1337 photochop skills (well, better than my non-existent skills) would be kind enough to chop a set of Volk TE37s in gun-metal onto this R32 GT-R for me -- I'm afraid this is the nearest to a side on shot of a gun-metal R32 GT-R I could fine -- if you have a better one, feel free to substitute:
And now the wheel:
The colour is a little off, it looks more like this:
Thanks guys -- just trying to work out if they will look good, or clash :( One final thing, is anyone sure what the widest rims you can legally fit an R32 GT-R is in NSW without engineering, and furthermore, what the cost of engineering might be?
Lucien.
They will look totally off their noodle... Best looking combo you can have!
Ignore my 2 second photoshop job... they will looks fantastic.
p.s. You do realise the R32 non-projector headlights are much cooler than the projector ones.
One clown referred to them as N1 headlights!???? He could have been right.
Anyway, they are different, so keep them!
Engineering is about $400.
click here for wheel modification legalities.
Thanks, although I think that has made me more confused. As I understand it, the widest and largest wheels fitted to the R32 GT-R were the BBS's that came on the V-spec 1 and 2, and they were 17x8s.
Now according to this doc, vehicles with an unsprung weight of 1201kg and over -- which I assume the R32 is -- are allowed to go up to 2" over the largest wheel that was offered on the car: in other words, up to x10s.
But, and this is what I don't get, your only allowed a 25mm increase in track-width.. Now track width seems to be measured from the centre of the rim on the left, to the centre of the rim on the right. So you halve the increase in rim width, then times by two, correct? In otherwords
17x9s = 1" increase in track
17x9.5s = 1.5" increase in track
17x10s = 2" increase in track
With 25mm (1") being the widest increase in track, the widest one could legally go on an R32 GT-R would thus be x9".
Is that right or am I just completely wrong?
Gojira: Thanks, I reakon TE37s are awesome, but I am trying to work out if the gunmetal grey TE37s would work with a gunmental R32.... Your photochop makes them look almost bronze/gold :P
Edit: My car has the projector style lights, which I prefer. I will be modifying them anyway for bi-xenon so I need the projector style :)
Lucien.
Sounds right, but I think its wrong. :P :confused:
Doesn't matter how wide the rim is (ie 17x8 or 17x10) so long as the offset is ok....
Fig 1. 17x8 inch rim
|_|-----|_| -> say thats a 2000mm track.
Fig 2. 17x10 inch rim
|__|---|__| -> that may now be a 1900mm track because the wheel sits further insde the guards than the 17x9's.
Fig 3. 17x10 inch rim with wrong offset
|__|-----|__| -> now you have a track of 2200mm because the offset forces the wheel to be further out of the centre of the car.
Does this make sense?
Christian
Arr, ok, so the offset helps to compensate? I didn't know that -- I thought it was basically there to ensure the wheel would clear the calipers.
So as long as I get the right offset, I should be ok even if I went to the max of 2"s? Can anyone confirm this from experience?
Thanks again guys -- appreciate the info.
Lucien.
Well, having never had any issues with the cops, I can't give any info on legal experiences, but i did have WORK 18x10's on my GTR for a while and the wheel track was less than standard because they sat further in the guards (we measured the track at UAS).
Christian
Anyone have a picture or know if a pair of buddy club p1 racing rims in the gold colour would look good on an white r33 gtst...series2?
i realli want to see wat it lookz like!
There are quite a few example pics on Buddy Club's website -- admittedly non of a
white R33, but a lot of white cars, and a black R33 with gold:
http://www.first-inc.co.jp/buddyclub/p1r/p1r.html
LW.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
