hey guys ,
lately iv been noticing stretched tyres is the craze , and its gotten me hooked . in saying that i dont have much info about it all to be honest.
firstly , as silly as it sounds but will any tyre place be able to stock me with some depending what i want ?
are they a different type of tyre compared to ones that are to suit a certain size rim ?
im thinking of getting LENSO D1R Drift Wheel 18 x 10 +22 for my gtst , and im after a real agressive look . im wondering if i run stretched tyres, plus some negative camber for mainly the front , will that be possible , with rolling / flaring of coarse
and what tyres would i be asking for when i rock up to the tyre place
thanks
attached is a pic of one of my r33s , i was running work equips 18 x 10 + 18 , it wasnt too low as you can see , but i loved the real tough look , and i did rep a lot of comments on them despite they were gtr fitment.
https://www.sau.com.au/forums/topic/395297-stretched-tyres-on-18-x10s/
cheers for the repsonce , but yes as for tyres and purchasing , as mentioned can i get the stretched tyres anywhere? and are they more expensive?
yeah lol another member bought them of me and had them on his r33 , i actually found the thread when searching for wheels to suit
http://www.skylinesaustralia.com/forums/topic/342504-work-equips-18x10-18/
All a stretched tyre is is basically using any tyre that is smaller in width than the recommended size for that width of rim,
The fitter "Stretches" the tyre as they put it on the rim.
No special tyres or anything, you can do it with pretty much any tyre you like, you just need to buy a smaller size width.
I have 235s stretch on 10" on my 15 for the rear
99% of tyre fitters wouldnt touch it as it's dangerous and if the tyre pops off the bead, you can actually get them into trouble
There's only one tyre place here that does it and that's where i got mine done
235s on 10" is not alot of stretch, doesnt even need any stretching techniques to make the bead seat on the rims, it's that easy
As for your rim of choice, i dont get why you would want to swap your Works equip for Lenso D1R??
As for tyres, any tyres can stretch but some are easier than others... And you need to run more psi on the tyres to keep the tyres from popping off the bead
Edited by ichi-go
not swaping mate , past tense , as mentioned i had them on one of my older skylines.
cheers for all the info guys , definitly answered all my questions.
now any recomendations of a place in sydney that will throw stretched tyres on for me ?
cheers
I had 245/35 on 18x10" wheels previously. A bit of stretch, not sure I'd really want to go 235. If you look at my topics there's pics in the for sale thread for them.
Anyway I just brought them to Tempe Tyres, don't think they'd have too much of a problem with stretching tyres for you and they're usually pretty well priced.
hahah yeah , one of my mates had some rims from there , he went to change his tyre to his space saver , and realised they threaded all the bolts on the wheels with the torque gun lol. ill just be taking my rims down there in my ute and have them chuck the tyres on there , fit them when i come home. ill be calling them tomorrow and confirming about the wheels and stretching them
yes definetily.
i also have one other question ,
obviously when the car is slow it will create some negative camber ,but for the front , if i want to create more neg to fit into the gaurd , what is the best way to do so ? iv searched up and read that people either use different bushes to dial , or either camber arms , but are there camber arms that will produce negative rather then correct?
and also i will get the gaurds rolled , but is there anyway i can get them pumped as far as possible without painting / or flaring ? i mean it shouldnt be too bad once some camber is there , its just a matter of getting them to sit right .
the other member who bought my equips seamed to have it quite well set - he has more camper compared to my shot and it sat pretty good. , but will there be much different in the +4 of offset , considering the equips were +18 , and the new wheels im getting are +22 , they should sit in closer if im understanding it right? correct me if im not?
With regard to guard rolling and pumping, PhillB on the forums rolled and pumped my fronts after the rears were wrecked by Tempe, couldn't have been happier and wished I had gone to him first - no damage to the paint whatsoever.
His details are on his website which is www.phillbenterprises.com or he's PhillB on the forums I think.
damn stories keep comimg up by the sounds . how much did he charge to do the car . cheers
also thanks for the replies , i am definitly more educated with all this , cheers men.
I think it was around $50 or $60 a corner, not too sure best to check with him. (That was for rolling and pumping/flaring).
And if i remember correctly it was about $40 a corner just to get them rolled at Tempe. The extra $10 or $20 per corner to have it done well is so worth it or you're looking at alot more to fix any damage/cracking.
Not educated enough. 255 is minimum legal width for 10 in. Stretching tyres is bad practice. Worst case scenario the tyre can be pushed off the lip and deflate rapidly during hard cornering but more generally the tyre will not work as well if the walls are not perpendicular. They will get hotter quickly and cornering ability is greatly reduced. Never mind the ones you have seen on drift cars - the whole point of drifting is loss of traction and grip ("controlled slide").
An extreme case of form over function where there is a real major downside. If the proper tyres won't fit in your guards get smaller wheels or pump out the guards. Negative camber is for better cornering at the expense of some accelerated tyre wear not for making wheels fit the guards.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
