More than willing to seperate the springs and shocks. I'm really surprised nobody just bought the whole package considering how much money people on here throw away on cars for such a little gain on the track. My package was awesome value for money.
I paid a lot for these because they had already been revalved a few times to get them correct for a 32 GTR. Pm'in you now Steve
Edited by Rowdyr32
  • Replies 95
  • 3 weeks later...
  • 1 month later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
