I don't want to fit a modified engine, I want it stock to get it running right before he goes chasing the powerz. I won't be fitting the turbo heat shield anyway so it should only be a few hours work to drop the turbo.
I think Alex was just pointing out that the engines aren't the same, and I should be fitting a det ecu into the V35. It won't work mate, too many ecu's needing to communicate to each other. I would rather try and trick the DD ecu into thinking it has a DD engine connected to it still.
The engines are essentially the same. Not saying there won't be issues to tackle, but I am confident I can get it all running with the EMU connected.
I would love to go a built 5AT in the future but at this stage im keeping the 4AT. It works and thats all that matters. Like scotty said get it in and running stock and go from there.
Wish my tax would come back already. Im very impatient.
  • 3 weeks later...
Ok kids its getting close. The parts list so far is:
-VQ25DET motor.
-Factory Turbo.
-Scottys dump pipe.
-Valve body.
Just waiting on tax return for Greddy Emanage.
All this on a maccas salary.
*dances like mr bean*
#NoFace
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
