Sunkist man, that was some bulls#@t mate. Even though his car is not to my personal liking you have to respect what he has done. A young kid with not much money said he was gunna pit a stagea front on a v35 and everyone laughed at him and said he was all talk and it would never happen. But what do you know he followed thru and actually done it. And surprisingly doesn't look to bad. So many kids say they are going to do the world and it never happens so yeah respect to this kid.
So tell me anyway Aaron, have you ever actually finished a car? Or actually really built one? if the answer is no leave the kid alone.
So yeah mark keep it up and please keep showing your build, very impressed that you have actually followed your dreams. Looking forward to seeing it with some nice well fitted rims. Oh yeah and boosts :D
Actually yes, 2 in fact. One being a Stagea lol.
I actually like his car. In all honesty it's different and I was waiting to see someone do it. There I said it.
But, his little smart ass attitude will not get him anywhere.
I can understand the hard earned savings going to it(being his pride and joy) and I and everyone else on the forum has done the same, but I didn't once mock this guy, until he decided to hark up with the name calling. If he can't handle it, don't give it. Pretty simple isn't it?
You post the car on a forum to get help, opinions, and advice.. Correct? Then don't cry when there is a negative criticism.
As said, I was probably one of the few people VERY INTERESTED in this when the thread first came up, haven't been in the section for a while, and came back to see Craig is still his good old self. And I get name called for pointing that out? Lol.
Like I said, I like the car, I liked what he had done, bar wheels sticking out but her, his car his choice. Came back to see more of it. Then he cried. What do u expect? Lol
We will be best friends soon enough, I just know it
Okay, this is the one-and-only warning to EVERYONE: all the name-calling, baiting, trolling and other crap will end immediately. Anything that looks in any way like a personal shot at something or someone else will be followed up by formal warnings, the temporary bans, and a permanent ban if necessary.
You're all (apparently) adults, so please start acting like it. Less of the schoolyard garbage please, I was hoping you'd all be beyond that.
I know we all like to stir each other up in a friendly way, but everyone should remember that words written on a screen are not able to express tone of voice and body language. This is why emoticons were created, right? If your post is meant to be a friendly jibe, then MAKE SURE it comes across this way - add a smiley or something. It's an extra few keystrokes on your keyboard, use it.
Right i get whats going on now. Im a bit slow. Hense why i have worked at maccas for seven years.....
Seems i have been played by one of the biggest shit stirrers around. Well played sir. Well played.
I am now the laughing stock!! Thanks boys.
Its on!
from here it started
What are you my thread hall moniter?
You bringing it up like you have is what makes it go off track.
Get over it. Everyone but you has got over it.
Edited by Howaitonaito
Hey josh...give him a break. We were all flatcappers or hard Parkers once upon a time. While marks a little bit of a smart arse at times I pretty sure most of its in misunderstood humour.
P.s plus I don't know whether his my kid yet...i had sexy time with this chick(I think....she was a little hairy) years ago and he does sort of look like a like me! A chick magnet! :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
