Hey josh...give him a break. We were all flatcappers or hard Parkers once upon a time. While marks a little bit of a smart arse at times I pretty sure most of its in misunderstood humour.
P.s plus I don't know whether his my kid yet...i had sexy time with this chick(I think....she was a little hairy) years ago and he does sort of look like a like me! A chick magnet! :P
furry muff
  • 1 month later...
Hey kids its been a while since ive updated this.
First of all i had a great time at the cruise. Craig and Theo did an awesome job. Hopefully i'll be able to keep up on the next one
Second of all i have sold all but one of the remaining V35 sedan parts with the bonnet left. All the funds will be going to "markneedsanemanage foundation" (feel free to donate) will busk if have to.
Thirdly the cam timing sensor can go EADC!
#NoFace
Edited by Howaitonaito
I'll do what I want with my farkin' lemons, you bloody young smartarse!
And it ain't calm, that's for sure!
Your memes are amazing, but it does make me wonder how you find time for anything else in life while searching for awesome memes
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
