Im leaving on the 20th to get it done. So not yet!
Dale were do you.......do you get bored at work or something?
Not really, just thought your thread needed a cat with ripped abs.
But then I though of this! They must've been separated at birth?
Weird huh?
Que: "the final countdown" by Europe.
One week to go. Only four more working days to go. Then two weeks off.
Driving a mates NM35 on sunday to get me even more pumped and i can not wait so its my VQ25DET fix before i leave.
You could say im getting pretty pumped!
i just realised josh that your display pic has been taken in kotara in my neck of the woods! come to newcastle often?
Yeah mate I'm from there and all my family are still up there. Plus I head up to see friends every few weeks
Leave tomorrow. Will be in melb hopefully without hickups around 4-5ish.
This is it guys. Its happening. Updates will happen as often as i can.
Ill try and upload pictures but since im doing it off my phone it may or may not work.
If not pictures will happen when i get back.
Was the drag from the huffy slider too much?
Lol
Good to hear. Get with the updates. And if you feel a prickly beard on the back of your neck in the night; run like hell.
Na slider is at home. Didnt have room in the car.
Will keep that in mind thanks alex.
Let me just say, there are so many differences between the engines, chassis and ecu/loom that I am worried this will turn into a nightmare. I had no idea it would be this much work. Hopefully it all goes as planned but it will take some time, anyone know Kanji? :P
After pouring over the Kanji DD skyline wiring diags, and realising there is absolutely nothing similar with the ecu (other than the connector) or the Re4 transmission controls, and not being sure the 'can' system would even communicate, we came to the conclusion the det ecu won't work with the 4 speed, and the DD ecu won't drive standard injectors, (or Emanage) without extensive rewiring/modification. It seems to be a big can of worms, around 200 wires to reroute and no guarantees it will work. :/
I think the turbo would have fit, but required custom cooler piping, as the starter motor is 3 inches higher. Also tapping turbo feed and drain fittings into the RWD sump was needed, as the RE4 and RE5 bellhousings are different.
The engine mounts were 4 inches closer to the engine, meaning the turbo intake would need to be custom made.
The chassis was different, and the Stagea front subframe wouldn't bolt up. This would mean major chassis mods, cutting parts off the Stagea wreck and swapping them onto the Skyline to remedy. This would make the car defectable. Possible for a track car, but obviously not a road car.
Sad to say it, but it is just cheaper and easier to buy a Stagea Mark... You know you want one... ;)
Yeah sad to see it all goto crap but hey. Scotty has done a mad job fixing all the little bit a pieced that was wrong with the existing set up, cleaning out the plenum and intake today and brake cut mod.
I now have stagea aero bumper with no fogs, have stagea aero sides on the way and a few other bits.
Now that this didnt work i think its time to save for a Y34 cedric/gloria. VQ30DET
  • Like 1
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
