  • Replies 51
I was wondering about how bad the suspension will feel at that power level. For a purely street driven car is it really only worth doing sway bars, strut braces, coilovers and new bushes or should you looks at adjustable camber arms tierods etc as well?
Edited by Mitcho_7
Yeah I think even a decent set of coilovers will bring it close to what I need with some fresh bushes
It's pretty scary to be honest I haven't unleashed its full power gain as its just to jumpy and bumpy.
Also with my 4x4 status it's got a lot of roll haha
would have to ask rocket industries what they are going for now. as far as how it went for me, before and after? no idea its been on there since the first tune was done as far as my power goes, its ignition system limited not knock limited.
mines the Stage 2 Boost Cooler Kit but i also have the 2.5gal (9.5L) upgraded tank and the solenoid upgrade.
http://www.snowperfo...ost-cooler.html
http://www.snowperfo...id-upgrade.html
http://www.snowperfo...-reservoir.html
if you can get the nitro booster, it does actually give a seat of the pants boost to your power.
Cops haven't bothered me for anything, however they will if you give them a reason to.
My engineers cert that covers coilovers, camber rod, traction rods, HICAS lock bar, wheels, strut brace, turbo, break lines, FMIC, and steering wheel is setting me back $1046
Mitch your whole car will be illegal unless your getting your turbo, z32 etc all certified.
Cops dont bother with coilovers do they?
At least from what I have seen with act cops they dont bother us
You make a strong point there, I guess as long as the car isn't stupidly low they won't give 2 squirts about suspension.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
