  • 9 months later...
Maybe that's what I've just had...two weeks of hell featuring tonsilitis, fevers, night sweats, migraines, vomit and muscle aches :(
And erythromycin can go and get fked. Looked up this nasty alternative to penicillin online...too little too late...almost every user rates it terribly because almost everyone gets the nasty side effects I just had. Can't believe they can prescribe such a drug.
After-effects of erythromycin can be candida symptoms unless hit quick with probiotics.
Think these are hitting me now. I've loaded up on yakult and probiotic choc balls. Have been dieting fairly sugar free so I'm hoping that all this is doing something...
Any other recommendations for candida? Worth getting a gut flora test?
Stage 1:- Kill back Candida albicans from system with a) Pau D'Arco say 3 a day & b) Neem 500mg caps also 3 a day
This kills it systemically
Stage 2:- Starve out the Candida with an anti-Candida diet (on web)
This stops any backlash
Stage 3:- Strong Probiotic a week after starting Stages 1 & 2
This assists digestion and cleans it out from your upper GI tract
Stage 4:- Echinacea/Garlic combo
This pushes the Candida down through the large intestine to the bowel.
Stages 1 & 2 should have a +ve effect by 1 week
Thanks Terry, will look at that. Can overgrowth confirmed with a guy flora test?
Genelle, I don't have any symptoms of thrush, but some people do depending how advanced it is. It's only suspected candida overgrowth at this stage, so I went on the anti-candida diet as a precaution and took probiotics...which can't harm me (it's a largely sugar free diet)...so I thought why not.
The only sort of reliable test is a "Dark Field Micro" test at some science labs.
Cytotoxic tests via Dr > pathology are fraught with too many false +ves and false -ves.
In the clinic I employ a Dr William Crooke Questionnaire. Is that on the net perhaps? If not I'll mail you one.
Look up erythromycin for more info...was prescribed by a doctor under the assumption I had a bacterial infection, and as an alternative to penicillin, which I am allergic too...though honestly I'd take the amoxicillin induced urticaria over the shitstorm that erythromycin hit me with.
Candidiasis Symptoms:- If you have 4 or more of the following, I'd attend to it.
* bloated tummy
* wind
* constipation or loose motions
* changes in your finger or toe nails
* urgency to urinate
* foggy thinking > affecting short term memory
* blocked sinuses
* rashes that come and go, especially in perspiration spots
* crotch itch
* halitosis
* post-viral cough
* post-nasal drip or catarrh
Has anyone done non-government site related research about the correlation between certain vaccines and their lesser known side effects? Pretty scary stuff...
You guys should look in to a supplement called L-Glutamine. It was touted for ages as "build more muscle!" blah blah, however that was soon squashed to be slightly plausible at best. It does, however, have a great off shoot.. It bolsters your immune system something awesome. Works with improving gut health and gut bacteria.. Not to mention strengthens the digestive-contained immune system. From which, I believe, a very large portion of pathogens enter through. The stuff is super cheap too, if you get it in unflavoured powdered form. I pay about $35 for 1kg. It's also the amino acid most commonly found within skeletal muscle.
Start off with 5 grams a day, mixed with a smoothie, water, etc. Usually in the morning. Work up to 20 - 30 grams a day, split evenly in doses. You'll notice your sleep will improve, muscle strength will have positive benefits, and your general sense of well being will improve. And you'll not have to worry about pathogens.. Combine that with some sort of fermented dietary change (adding in sauerkraut, natural yogurt etc) and you'll be laughing.
What really gets me is this whole concept of "cold and flu" season.. I mean, the pathogens responsible don't suddenly say, 'Guys it's winter! lets go mess some people up'.. Then the health organisations will tell you, "Oh but it's because of the people all being around each other in enclosed spaces" .. Pfft, what a load of nonsense.. People are far more likely to socialise in greater numbers in summer. And the same amount of people still use the train for work, work in the same buildings, do the same things..
But, I digress.
Vitamin C, L-Glutamine, fermented food/drink, green tea, and enjoy a good dose of chilli... delicious :D
Anyone else tried the glutamine approach? Or read about it? If so, what was your approach? If you chose not to, what was your reason? :)
I think it's more because immune system resistance drops in the colder temperatures, leaving us more susceptible to catching shit and therefore transmitting if. Plenty of colds going around in summer but I have definitely had more in winter.
Question (this may have been answered somewhere along the line) but it's come time for our office to have flu shots. I am not going to get it this year on the basis that the last 4-5 years I've got the jab, then fallen ill only a few days after. Sometimes just for a few days others I have been confined to bed for at least a week.
Why is this? I eat very well, lots of exercise. Fwiw I even had a cold a few years ago, went for the flu jab, told the lady I already have a cold.. She said I would be fine (bitch won me over with a red lollipop (red is the best)) but yet a day or so later I felt 100billionty times worse
I don't think you should have it either.
Some people have a high degree of sensitivity to vaccines - more so live vaccines rather than dead.
For you, prevention is paramount. But if you do cop it I'd get Chinese Acupuncture and if you're quick enough, esterified vitamin C, zinc and echinacea/garlic.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
