Hey guys, as the title says i've got a cracked rim and i'm not sure what to do.
I was giving my R33 its usual weekend clean and noticed a crack on of the spokes of the front left rim... I havent noticed it before and i'm just wondering what could have caused it and what i should do.
If anyone could tell me if its safe to drive on at all or if i should get it repaired or get a new rim i'd appreciate the help. I'm not loaded either so the least expensive/time consuming solution would be great.
Its a genuine Rays Gram Lights 57C (17 x 7.5 + 30) if that makes any difference.
Cheers
Nev
https://www.sau.com.au/forums/topic/396415-cracked-rim/
If you bought these rims new, then not only should they come with a 12 month manufactures warranty, but you also have an implied warranty. Basically that means they should be fit for the purpose they are designed for, be free of defects, and should last a reasonable amount of time under normal conditions.
http://www.accc.gov.au/content/index.phtml/itemId/815360
https://www.sau.com.au/forums/topic/396415-cracked-rim/#findComment-6297260
Thanks for the replies guys, I put the rim back on the car this evening and as I let the jack down the spoke just snapped... Cant drive on it either way now haha I'm just happy I wasn't going down the highway when it happened.
They came with the car so I doubt id have any luck getting a refund or a brand new one
I've found a replacement pair for the front (cheap too) which I'm having a look at tomorrow.
Thanks again for the replies and help
Nev
https://www.sau.com.au/forums/topic/396415-cracked-rim/#findComment-6297477
Cheers for the help again, got my new pair of rims yesterday which were in mint condition. Turned out to be an inch wider so they rub a bit at full lock... look the biz though as they sit pretty well flush.
They came with a brand new pair of toyo proxes t1r's so i thought a bargain for only $300.
Will be doing a regular check from now on :)
https://www.sau.com.au/forums/topic/396415-cracked-rim/#findComment-6298740
why not put them on the back then? or do you already have wider rims on the back?
https://www.sau.com.au/forums/topic/396415-cracked-rim/#findComment-6298790
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
