Hey guys, been noticing more and more what look to be scratches (and paw prints) on my car from the neighborhood cats. They are not deep so they should polish out but I want to know how I could stop them getting on there...
I've bought a cover to hopefully try stop any marks of they do get on there, thought about baiting them although it isn't really viable as I've got 2 small dogs.
Anyone had any similar issues and any ideas how to prevent them? Was thinking of finding something cats really hate and spraying it on my car cover...
https://www.sau.com.au/forums/topic/396578-cats/
You think you got problems mate I have 2 rather large amstaffs that like to use the roof of my car as a lookout to see over the fence..was resprayed about 5 year ago now my paint is rooted..i tried building a fence and they tore it down..i tried kicking their heads in but it just makes them stupider..
The only success I have had is coating the car in wd40, that way they just slide off..but as you can imagine this isn't great to wash off..
But your best bet maybe coating your car in something the cat hates stuck to its fur, that way it will get sick when it licks itself..a heavy wax or something may do it..
GL...
https://www.sau.com.au/forums/topic/396578-cats/#findComment-6298897
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
