Its a snake thats living under the plenum.
Send an Owl to Harry Potter and ask him to translate, he can speak Parseltongue.
Have you tried increasing the revs a bit to see if it does it above idle? Change the hose on the FPR?
Maybe post a video. Cars make all sorts of noises and people describe them differently so its hard to E-Mechanic it. But my stock injectors and my Nismo ones definitely dont hiss at all at idle.
https://www.sau.com.au/forums/topic/396689-hissing/#findComment-6300192
There is a PCV hose that is plumbed into the rocker cover near the front of the plenum. It is connected via a push-in one-way valve.
Mine sometimes has a hiss from there- maybe have a look at that? Might have dislodged it/damaged it when replacing injectors.
If not, shoot it with a 12 gauge but leave one in the pipe in case the snakes are hunting in pairs.
https://www.sau.com.au/forums/topic/396689-hissing/#findComment-6300580
I checked the lines and cant find the point of the hissing.
Might rig up some ear muffs with a hose on the end to pinpoint it.
Hermione rocked my world last night I just sent her to your place via platform 9 and 3 quarters.
Ohh and Game Of Thrones is an epic story of knights & dragons etc.
Recommend it heavily
https://www.sau.com.au/forums/topic/396689-hissing/#findComment-6301009
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
