VultureMotorsport Posted October 16, 2012 Author Share Posted October 16, 2012 Hi, PM sent - correct the ID's are actually EV'14's just flow matched by injector dynamics. Not sure about the milling though as I haven't heard of it. - Brendan Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6581982 Share on other sites More sharing options...
vkadam Posted October 16, 2012 Share Posted October 16, 2012 I have not got any pm from you. Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6582333 Share on other sites More sharing options...
JustinP Posted October 16, 2012 Share Posted October 16, 2012 Hi, PM sent - correct the ID's are actually EV'14's just flow matched by injector dynamics. Not sure about the milling though as I haven't heard of it. - Brendan Can you please also PM me a price for the ID 1000cc injectors to suit an R34 GT-T, with the plugs. I'm looking for something that is pretty much drop in on the standard fuel rail. Thanks Justin Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6582552 Share on other sites More sharing options...
VultureMotorsport Posted October 16, 2012 Author Share Posted October 16, 2012 I have not got any pm from you. PM re-sent Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6582712 Share on other sites More sharing options...
VultureMotorsport Posted October 16, 2012 Author Share Posted October 16, 2012 Can you please also PM me a price for the ID 1000cc injectors to suit an R34 GT-T, with the plugs. I'm looking for something that is pretty much drop in on the standard fuel rail. Thanks Justin Hi, These would not be a direct fit as they are universal injectors, but with extensions and plug's I can do 6x 1000cc EV14's for just $630 incl. delivery! These are readily used on the R34's so installation is no major issue if using an experienced workshop. - Brendan Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6582714 Share on other sites More sharing options...
ADUBZ Posted November 8, 2012 Share Posted November 8, 2012 Hi mate I'm looking for some E85 1000cc injectors to run in a BNR32 with 11mm HKS rail, SARD regulator & warlbro 450lph pump, cheers. Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6616852 Share on other sites More sharing options...
VultureMotorsport Posted November 8, 2012 Author Share Posted November 8, 2012 Hi mate I'm looking for some E85 1000cc injectors to run in a BNR32 with 11mm HKS rail, SARD regulator & warlbro 450lph pump, cheers. Hi, I would go with the BOSCH EV14's 1000cc top feed injectors. They are E85 compatible and come with extensions to suit 11mm o-ring. Can do 6x with extensions and USCAR plug for $630 incl. delivery - Brendan Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6616864 Share on other sites More sharing options...
89CAL Posted December 10, 2012 Share Posted December 10, 2012 Hi Chasing some prices on 700-800cc injectors for RB25 (Side Feed) May be interested in going top feed if there is a good deal on a package however Thanks Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6661467 Share on other sites More sharing options...
VultureMotorsport Posted December 10, 2012 Author Share Posted December 10, 2012 Hi, The side feeds would be $150/injector so if you can go top feed that would save a lot of $$$! Top feed BOSCH EV14's 1000cc are $640 incl. delivery for 6x which include the extensions and plugs. - Brendan Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6662051 Share on other sites More sharing options...
89CAL Posted December 10, 2012 Share Posted December 10, 2012 Hi, The side feeds would be $150/injector so if you can go top feed that would save a lot of $$$! Top feed BOSCH EV14's 1000cc are $640 incl. delivery for 6x which include the extensions and plugs. - Brendan Hi Brendan Thanks for that, so with the injectors, extensions and plugs they are pretty much plug and play (minus the rail of course) or do they need the resistor pack? Thanks Callan Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6662347 Share on other sites More sharing options...
VultureMotorsport Posted December 10, 2012 Author Share Posted December 10, 2012 Hi, They are practically plug-and-play but you would need to contact a workshop to get specifics on what else may be required. These have been widely used on the R33's so certainly no major task as all. Also note these are the same injectors as used by injector dynamics! - Brendan Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6662721 Share on other sites More sharing options...
portaz Posted January 22, 2013 Share Posted January 22, 2013 hi there I am after a set of injectors for 450kw gtr im thinking id2000? How much for 6 with the required adaptors to fit stock fuel rail and connectors I assume they are not plug and play and need some work from the tuner? Scott Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6717785 Share on other sites More sharing options...
VultureMotorsport Posted January 22, 2013 Author Share Posted January 22, 2013 hi there I am after a set of injectors for 450kw gtr im thinking id2000? How much for 6 with the required adaptors to fit stock fuel rail and connectors I assume they are not plug and play and need some work from the tuner? Scott PM Sent Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6718468 Share on other sites More sharing options...
ouzy Posted January 24, 2013 Share Posted January 24, 2013 (edited) hey can message me your address of ya showroom cheers. checked your website but couldn't get an address. Edited January 24, 2013 by ouzy Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6721311 Share on other sites More sharing options...
VultureMotorsport Posted January 27, 2013 Author Share Posted January 27, 2013 Done! Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6724444 Share on other sites More sharing options...
shnaped_second Posted January 27, 2013 Share Posted January 27, 2013 pm sent Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6724643 Share on other sites More sharing options...
VultureMotorsport Posted January 27, 2013 Author Share Posted January 27, 2013 Reply sent Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6724717 Share on other sites More sharing options...
SiR_RB Posted January 29, 2013 Share Posted January 29, 2013 pm sent Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6726960 Share on other sites More sharing options...
VultureMotorsport Posted January 29, 2013 Author Share Posted January 29, 2013 pm sent Replied Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6727055 Share on other sites More sharing options...
Sarumatix Posted February 2, 2013 Share Posted February 2, 2013 Trying to find a set of preferably ID2000's to suit R34 RB25 NEO running E85. Link to comment https://www.sau.com.au/forums/topic/396873-performance-fuel-injectors-1600cc-440cc-2200cc-1000cc-725cc-875cc-650cc/page/3/#findComment-6733554 Share on other sites More sharing options...
