Hi All,
In planning my trip to Japan, I wanna visit Top Secret which is in Chiba and I believe there is a HKS workshop also in the same area.
Can anyone please give me the addresses coz I wanna go find it. I am in desperate need of a Top Secret and HKS jacket!!!
Are there other cool workshops which would be easy to get to in the Tokyo area? I also want to head to Autobacs but I hear that's pretty easy to get to.
https://www.sau.com.au/forums/topic/39707-where-is-top-secret-and-hks/
TS is in north Chiba. Get off at Chiba-kita on the Higashi-Kanto expressway, take the left exit after the toll booths and head down the main road about 400 meters. You will see TS on the left side in from a side road. Its right opposite a large second hand car reseller.
http://www.topsecretjpn.com/
Other places to visit? Nismo Omori Factory in Omori, near Shinagawa (you can see accurate directions on how to get there on another thread in this section), Honda HQ in Aoyama, Nissan Gallery/HQ in Ginza, Mitsubishi HQ Showroom in Shinagawa, Cornes in Shibakoen(should be getting the 612 Scaglietti soon). Autobacs in Shinonome is ok, but quite expensive if you want to buy parts. There is an ASL & Tommy Kaira showroom right next to it with lots of cars on display so its definitely a must. Crystal is your best option for well priced parts, there is one close to TS in Chiba. Mine's is close to Kamakura is you happen to go there for the usual tourist visit. There is a Prince and Skyline museum in Mitsukaido (Ibaraki-ken). They have a nice collection of rare cars, and Tsukuba circuit is about a 30 minute drive from there. The museum is a 5 min walk from Mitsukaido station.
Thats all an think of at 12am:D
Leewah. Easy by train.
Depending on the line you will be on, catch the train to chiba then catch the monorail to a station called "Sports Centre".
On the left of the station is the main road. Walk down the steps and turn right and head down the main road.
a few hundred metres down on your left is a Mcdonalds and next door is Crystal (highly recommended)
Unless you feel fit, hail a cab to get from there to Top Secret which is on the same side of the road but several km's further.
I think I've got the Top Secret part worked now. Does anyone know of a HKS workshop I can visit and get cool merchandise from?
As you now know, I'll be travelling by train, so any help is still greatly appreciated.
BTW, if I catch a cab to the Top Secret factory, will the cabby speak English (Engrish) or at least know where I want to go?
  • 1 month later...
welcome back home dave... so what didja get upto in japan? did you try and explain your car to the japanese tuning houses? if you did were they impressed or have any tips for ya?
  • 4 weeks later...
  • 3 months later...
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
