  • Replies 7.5k
Posted Images
Went to Marion Shopping Complex for a movie! Saw lots of skylines on the way. Saw one red R33 with a custom number plate - 'DRIFTIN'. Guess what...the car was driven by a woman with a few kids in the car. Unbelievable! :domokun:
On the way back, saw a black R32 stopped by a police on Anzac Highway. Not sure what the guy did wrong thou....... Hope he didn't get DEFECTED....
Saw a nice white 33 GTS-T last night about 11pm on North Easr Rd heading towards town. Had Vic plates which may have been chosen to read from the rear view mirror - execpt they said the wrong model.
i swear.. wherever i go i see that silver r34 with the big crome rims and bomex kit!
spotted on south rd, regency rd, west lakes mall, gouger st.. all within 2 days? very nice car though...
yeh i see that car as well, saw it on hindly last nite near cargo...
ok i didnt believe this but my mates keep telling me that thy have seen my car cruising around, but mine's been in shed for last two weeks. anyways, today i decided to drive it. and what do you know, the 1st 'line i spotted within 10mins of leaving home was a exact copy of mine. damn adelaide is small. *end of conspiracy theory*
haha Duc - you should have kept the stealth spoiler the dodgy fibreglass black it used to be - so we can identify you easier :P .... hey if ever you're passing by my place drop in, as I still have Iceduck's R34 wheel centre caps in my garage - I keep meaning to ring you or something ....
hahaha finaly got it out...yeh i though i saw another 1 like urs in ur area last few nites as i been driving up that way...
whos up 4 a coffee or sweet 2nite/small crusie from meet point to cafe lol?
Yeah moved mine yesterday and did damage to the guard now farken :mrt: Need to raise it...
anyways keep seeing this chick driving a white 33 with black graphics/flame job down the sides, seems pretty decent looking (the chick that is :D)
Cubes... i need to get a triple plate!.... Come to think about it there was a bit of oil lying around the road... It was open wheeling a little bit in a couple of those vids come to think about it!!! So the diff is probably on its way out too!
Anyone know the prices on a gtr V spec rear diff?
Saw an awesome white 32 gtr on parade today... lots of black smoke coming out exhaust (needs a bit of a tune i think! running a bit rich!) Sounded awesome though!!!
Saw Phat34 last night!!! (and man that car is phat -- told me he had over 400+kw at the rear wheels and it sounded like it too (its a pity he had a defect sticker)) Hope to see you rolling one day again soon!!!!!
Perhaps the best 34 i have ever seen!
Has anyone noticed all the symbolism through out Napoleon Dynamite or is that just me? :rofl:
I dont know about a conspiracy but maybe some theory!!!!
Would you like me to teach you guys so you can open your eyes, hopefully this riddle doesnt turn into a shizzle mynizzle fizzle? hehehehe
Have anyone seen V or Davinci code front cover inside and out?
Why a tripple plate. Don't over clutch the car there is simply no need.
A good 9 puk single with a nice flywheel will be fine.
A twin is better though.
Its most likely a standard run of the mill VLSD.
or.. Only you would know this.. Does it run an active LSD as some of the later *don't really know to much about the 33's in this regard* do.
Drive it until it gets too loose then drop a mech lsd in to it with some castrol oil.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
