naw he said the pump is pumping fine
sorry cant be more specific he was talking about it and i wasnt sure if he ment he was gunna look @ it then for the air leak and mentioned regulator but didnt think it was that
he took the AFM off i think the young fella sprayed it and after that it made the 175KW
i got it on camera but its very poor and all you get is mostly sound which distorts over like 4000rpm
  • Replies 7.5k
Posted Images
im fairly sure the stock pump cant handle much more than 175rwkw, thats where mine cut out anyway. i went for the bosch 040 internal, they handle up to 250kw. it made a huge difference, very valuable upgrade that one! :whistling:
ah ok sumthing to look into them whats the cheaper walbro (not sure spellling like the $180 one)
here is link very very poor footage
http://www.youtube.com/watch?v=qPr4_TLD0iY
I got Shaun to put in the Walbro FP and i have had NO issues with mine also.......buth pumps are pretty identical!
my R34 is leaning out in the top end, and I think I would be making a little more power than that - so I think it is true what Sam said. I have just bought a Walbro 255lph pump off Ebay for $125 delivered .... and am going to chuck in a Sard fuel regulator while I'm at it - then get the SAFCII tuned by Donnon, to hopefully make around the 200rwkw mark I am hoping. :whistling:
yeah he didnt push it was possibly leaning out too much or sum other issues i forget
i know after 140kw he wasnt happy about that and knew there should be more in it thats when he took the AFM off and started looking arround @ stuff
i didnt bother getting the dyno chart cause it was incomplete
anyways off to bed got a wedding to drive in tomorrow :whistling:
Edited by Madaz
yeah, I have an 044 in mine, and it's making about 200rwkw (estimate!), I would have thought the skyline setup would streach a bit further than 175?
The cars are getting old.. They pumps are getting lazy. :whistling:
Mine crapped out at around 67,000km's and 160rwkw.
spotted a chick in an orange 32 with front bar in primer coming out of modbury triangle. Also a P plater chick in a maroon r33 down port rush. Looks like most hotties are getting into imports now...
hah the orange 32 is flick from CSA / SHY, luke (skylineguy19) girlfriend............her old car was the black NOT URS lancer..........the car was owned by a chick called erin from NS i believe....
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
