  • Replies 7.5k
Posted Images
Over the weekend finally spotted in town that yellow baby Lambo (Gallardo) everyone keeps mentioning. Then on the way home I left a trail of drool on Nth East Rd while following this F430 :laugh:. When I pestered the owner obliged to the 0-60km, would have luved to hear it at wot though.
Unfortunately had to peel off & leave the stallion to quench my thirst at Sub-way (Modbury), where one of my twins decided to park nxt to me :mad:.
Edited by pkblade
blade you car is a fair bit lowered hey
nice ride
Cheers Steve, fingers crossed she should be nicer to look at come SCS :rolleyes:.
Its not overly low, from center of wheel to guard is approx 360mm (front) & 350mm (rear).
yeah that was me - was having a coffee in Cibo .... yes, I backed into a dam stobie pole the other day pulling out of someone's driveway - the stobie pole was literally on the edge of the driveway in my blind spot. Made a bit of a mess, which I am absolutely spewing about. Now I just near someone to rear-end me so they can pay for the repairs :) It's not too bad though - so I will leave it as is for the time being :)
I spotted my doppelganger in Grenfelll St just before I parked - a black R34 4 door (with Qld plates) that people (including my wife) keep mistaking me for.
OMG.. what area are you in..
Ours and Miss Nismo's garbageman go down our street at like 60-80kms an hour. I don't think they even care about the bins.... If they take the rubbish, thats a bonus.
Least you got blackies to prove it!
NOte: freakin quote button didn't work. Was in relation to Madaz comment..
Edited by CheekyR32
Works for me, but thanks, I missed the garbage man burn-outs post.
What a pisser! :)
up banksia park
yeah he stoped doing it for six months and it started again
im not normally a whinger but i have a 5 year old daughter and theres other younger children over the road
plus i think if that was me in my skyline doing it i would get a huge fine and prolly my car confiscated so why shouldnt he be warned @ work too
Spotted a white R33 on Goodwood Road on Saturday, near the showground. Lady driver... :) I flashed my high beam (just thought of saying hi), but she couldn't be bothered at all. I guess she must had thought that I was a wanker trying to blind her out while she was driving. :yes:
Anyway, spotted a weird guy driving an Alfa Romeo. I was driving at 60 and he overtook me at 60 zone and showed me a thumb down. :happy: sad case..... :P
Spotted this morning at about 6:45 while at the lights on corner of South and Richmond Rds a white S2 33 heading south looked nice and clean with a kit n wheels, then 2 sec later heading north a black 180 slammed on some 18's looking sweet as!
Oh and a white 33 GTR at the lights on Greenhill Rd yesterday arvo about 3:30, olderish looking chap and the car was rather stockish, looking sweet none the less!
Edited by Deluxe
Now I just near someone to rear-end me so they can pay for the repairs :O It's not too bad though - so I will leave it as is for the time being :)
my front bar has had a thrashing, let me rear end u and we can split the excess? lol
spotted a white 33 at cafe de villes last nite (wed) at about 11ish, blond chick driver..any1 here?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
