  • Replies 7.5k
Posted Images
I wouldn't be so fast to make a blanket statement that all 19's are crap. If you have a look at alot of the euro and japanese touring cars running massively large aluminium rims.
But I see your point, alot cars these days run 19's for the bling factor. Which is okay I guess if it's just a cruiser.
On another note... knickers?? :(
I doubt many can afford one 19' aliminium not to mention a set. 19's make handling really crap, I mean with my 18's its on the nerve of giving me the sh!ts. I dont think they contact the road as good as 17's or 16's would. I might be wrong but alot of people - general public that is, not talking workshop cars, use 16's predominately or 17's when running down the strip.
Anyone seen or know of a dark blue rx8 with a very very low bodykit (Wise sport type) going around Adelaide sporting trade plates. Apprently it has force induction of some short.
that would be nice the Rx8 has 186KW NA which would = arround 150RWKW not to bad for a 1375kg car
Yeah looking at your avatar just reminded me of it. Was on main north rd going towards town when i was heading home. Just heard a loud bov flutter and it went pass. Also heard a bov flutter from a civic sedan on the parade. I wonder how they would go being fwd and all.
nice Madaz - thx for the artwork. I was going to do it, but now you saved me the trouble :(
Yeah I have seen a Silver 350Z with some sort of turbo setup too - big intercooler in the front gives it away!
Has anyone here actually driven either a 350z or rx8 (some ppl on this forum says the mazda 3 turbs are better). Opinions besides the looks - exterior and interior.
yeah ive test driven the Rx8 very nice 6spd manual leather int. 18" rims was very comfortable yet had the feel of sporty wanna get up an keep going
yep I looked at buying both a 350Z or an RX8, and drove both a few times. Both very nice - handling fantastic, awesome leather interiors, lots of toys etc etc. However both were quite underpowered with very limited ability to modify - plus were going to be a $30k+ changeover from my S15 (which in a lot of ways is a better car) :(
I heard of a fairly low km RX8 selling in the Eastern states for $36k the other week - so am damn glad I didn't take the plunge now!
Gosh $36k and not even an 'import'. Im thinking a VQ would be on par with a N/A rb25 if not better due to its higher displacement. No doubt the interior of the 350z are awesome, just curious as to how good it would be in stock form - say the track spec one's. Never driven a car at the showroom's before, is there alot involved before they let you give one a go I wonder..
just drop in in your line and have a chate if your serious they dont even care if your not
i wasnt gunna buy a Rx8 just wanted to drive 1 :( i was on the priority list for when they first came to adelaide cause i signed up @ the mazda site
sp[otted this http://www.carltonaudiovisual.com.au/?q=node/view/475 :) verry nice monitor/tv
Edited by Madaz
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
