  • Replies 7.5k
Posted Images
I spotted a bayside blue R34 number plate GTTR-34 in the city last night ..... and of course spotted Vange parked in Rundle St .... also spotted Chris's morone R32 with chrome polished R32 rims at Autobarn Gilles Plains where I went to buy 20% off Motul 300V oil - I think I heard on the radio that all stores everything 20% off for the weekend, so anyone needing service (or other) items rush in! I got 4L of 300V plus an oil filter for $79 - BARGAIN!!!
no worries Luke
Steve - nah it wasn't me - I was in MattRs Magna last night on the way in, then the wife drove home in her Accord Euro - I was in no condition/mood to drive :laugh:
spotted a few 33s in the city last night cutting laps, one i saw the most was the yellow one with black/carbon bonnet (i as pretty pissed lol didnt look too too hard lol) but yeh saw that heaps. and a few black 33s with 400r kits low lip spoiler......
Spotted Madaz saturday night in freedom car park, or more correctly he spotted me, always good to meet another sau member, hopefully next time we can chat longer!
Also joined the "i spotted vange club" on saturday night parked on rundle street!
Spotted Leeman last night around 6pm, was walking towards womens and childrens hosp, at the gardens when spotted you while eating pizza.
are you sure, cause i didn't leave the car show till 7! might have been different skyline.
Yeah was you was going by my watch, still havent changed the time on it, and just a rough estimate to the time. If someone has the same colour 34 with the same front bar as yours then maybe...
Spotted tonight SECRET, thought was a GTR with those wide front guards when pulled up behind me. Then when taking these pics spotted a black? 34 cruisin past along seaview rd henley beach. On way home spotted white 32 at lights on anzac hwy heading towards bay.
Think is plenty of room for more skylines (and more bird sh#ts), taken at around 8pm so get there around 6pm for good clear sunset shots.
Edited by gts33t
Spotted YTRYME on Pulteney St. at about 11.30pm on Saturday night. Was 'queuing' at the traffic light to turn into Rundle.
Nice pics you've got there Brad. Try decrease the shutter speed of your camera a little bit more next time when you are in such a nice scene. Then, you might be able to see more details of your car plus the nice view at the back. Not unless that was delibrate. Just an idea thou ..... :P
Edited by bixby
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
