  • Replies 7.5k
Posted Images
Nah Vange, wasn't in North Adelaide today, just went past (must say the job is shaping up quite nicely if you haven't seen it yourself) I park in the North Adelaide village underground park, that's why you don't see my car on the side of the road :P
those oh boy plates used to be on an orange s13. I see the s1580 around now occasionally too
Thats my mate Cas, she should be coming out to the photoshoot, and its a S15 not a S1580, and yes she is gorgeous.
spotted what i think mite hav been howie's 34 (judging by the avatar pic) last nite.
7:30ish, south road / daws road lights..........was in an army hilux, seen the 34 and thought it looked familiar
at the same intersection this arvo i seen a maroon 33 with gtr wing, white lh guard and no front bar (and a lil blondie driving)
Hey matty, nope that wasn't me. I haven't been down that way for a while.
Spotted Howie's car parked at Grater Union arndale at about half past 3 today.
lol arnt u meet to be at work? =p
LOL that's me bro. Parked close to a Accord with 18" ray rims? :no: Ummm yes i was meant to be at work, but i got off early :P
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
