  • Replies 7.5k
Posted Images
Thats a tidy R33, it use to have INTRUDA no# plates. The owner was part of the GRC club, I only remember cos of them vvv :)
Madaz - Did you check out his bonnet with the 20kw stickers :).
blonde with the white skirt ummmm very nice
Saw Heslo yesterday afternoon, parked behind Adelaide Uni at about 12.00pm. Like that reverse parking (at 45 degs angle park) you did.. made your car stands out more! :D lol Nice and clean ride!... Oh ya... I think you left your Nokia N70 in the car as well..... a bit dangerous thou. :)
Thanks bixby, yep, that was me, the N70 is a dead phone, got it off a mate, tried to fix it, no such luck. :D
Funny you should say about the reverse park, turns out that is an illegal park (atleast in the eyes of the retarded parking inspector) he wrote on the ticket (Failed to park at a 45 degree angle) I've disputed it already trying to get out of it as I did park correctly and how I parked did not hinder anybody else so I'm hoping I'll get off.
Dan, still not fixed yet, goes in on the 5th of Feb so I can't wait!!! :)
did you take a photo of the way you parked
spotted last night a little bluebird with sum ok rims prolly 16" and a CA18DET and my god it was loud and flew
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
