  • Replies 7.5k
Posted Images
I saw a light blue R32 GTS with the plates NISMO 2 heading away from the city going down anzac highway, really nice looking bodykit on it.
A yellow R34 GTS-t with the plates SLY 34 on pulteney street at the end of rundle mall in the city.
A R33 GTS-t with the plates BB 07IY in a happy wash on south road at bedford park, just before the goodwood road turn off. Was a really nice green/aqua colour.
see too many 'lines to spot em all day. nice one this morning was the white R33 with white 17's, looked very clean.
was that white 33 on sir donald bradman drive near autobahn intersection and were you driving a maroon 33?
if so that was meeeee
spotted a few skylines at HJ's on West Tce
i did take pics but they didn't turn out to good but who cares lol
there was 1 there with the no. plate BLKSKY
Hey, didn't realise you took a photo of my friend's car (the black one)..... were you using a "spy" camera ?? lol..:huh: .. I was sitting at the Hj's open area with my friend chatting about cars.... were you the one with the red jacket? I would had said 'hi' if I knew you were Pokie....... :( it's alright, we skyline lovers have plenty of chance to meet sometime in future cruises..... :huh:
Edited by bixby
red jacket?? no i was the 1 an orange boob tube top
haha would've been cool if ya did say hi, but next time
hopefully :huh:
haha spy camera, tis a digital camera man, was using it to
record mine and a friends "drunken-ish adventures" :(
hj's open area?? is that the inside or outside?? :S lol
Edited by pokie
All of those that were out at the drift practice last night.
It was a good night.
Skyline
and the 31 club boys and girls.
Sorry to anyone else that was there that i didnt know.
saw a few cars out friday night, saw the small SAU cruise up mt lofty, Met Patrick/Pkblade.
Also saw vange a few times, once when you came through freedom carpark and again at jms.. shouldve introduced myself sorry, i was the one leaning on the orange 32, getting bored.
Last night saw a nice yellow r33 gtr, as well as a custom paint job 33 in metallic purple with a couple of girls in it. and quiet a few silver 33's down anzac. and the black 33 at hj's on west tce that pookie pictured...
Considerin drift prac and the shitfacefest was on there was fair representation out...
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
