Last night (11pm) after watching a movie at TTP, mate & I in his Starlet pulled up at the lights next to a blonde in a stockish kitted silver R33 GTS-t. We were trying to see what front bar it had (looked similar to R34 designs) & she must of thought we pervin at her or something coz, next second she gunned it but only to be caught on the next set of lights 40m's down :sick:.
Also, early this morning in Gilles Plains spotted another blonde girl driving a wine red R33 with some very ugly wheels.
  • Replies 7.5k
Posted Images
I see a silver 4door 32 every day nearly either on tapleys or the raod that crosses between taps and morphett at bout 630 in the morning or 400 in the arvo. looks tidy, low but never any aknowledgment. ya get that i spose
Edited by mad032
spotted a white stagea with nismo wheels on anderson walk (i think, im friggin useless with street names) cruising towards munno para shops at about 7:00.
looks awesome, makes me want a stagea, lol.
That would be my new baby, got bored while the 260 is getting rebuilt and bought it about 2 weeks ago! lol!
looks awesome man :)
seen it around a few times, must bug you for a ride one day :kiss:
Spotted Clean33gtst on the way to work again.. Dead certain you spotted me also.. ;)
Were you in the White 32? If so, saw ya. Gave a half wave, was half asleep this morning. :(
Sure was mate, The look on your face was rather GOLD.
Im not sure if you were quite awake.. and if you were staring at me or not lol ;)
hahaha. Not staring at you mate. Was staring at your beast :(
spotted hostile this morning,
sorry mate i didn't see ya till the last sec don't know if you noticed me waving???
how long were you driving down the road with your arm out the window?
Yeah not long mate... I only saw you as I was almost alongside!!
Spotted Silver R34 GTT Series 1 with Gold Rims this morning on King William Street.... i gave you a bit of a boost as i went past :P
Might have been my old car if the gold rims were BBS LMs...
He took the car down the Bay last night - it seems about a dozen of my mates spotted it, and called me up thinking I was down there lol. I rang him and told him to go home :(
Spotted Clean33gtst on the way to work again.. Dead certain you spotted me also.. :P
Get your 260RS fixed BEN!!@! ^^
looks awesome man :(
seen it around a few times, must bug you for a ride one day :P
Yeah 260 should be back together again next week cola! Cant wait for it!
And Scandyflick, we'll have to organise to catch up one day, im guessing you cant live far from me, im down off curtis road?
yeah, im not too far from there.
im just up uley near the highschool.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
