wow, from all I have read, this is fast becoming my new favourite car :O
Check out lots more pics here:
http://cgi.ebay.com/ebaymotors/2007-Noble-...2QQcmdZViewItem
loooooove the dark metallic purple, and the black ones!
  • Replies 7.5k
Posted Images
wow, from all I have read, this is fast becoming my new favourite car :laugh:
The specs look quite impressive, that's for sure. It's unique too, not just another run of the mill Ferrari :)
Saw Brad (sorry mate forgot your new user name) on Happy Valley Drive just after 5pm
I've loved the noble for a long time now unfortunately the bank funds don't spread that wide. Its one of the reasons i like turbo cars i always preferred V8's then i saw the power and speed they were getting with relatively small no's.I remember seeing videos of them a couple of years back and they are such a fast car in street spec and they handle fantastic. Lee Noble should know what he's doing in building sports cars, He was one of the engineers that designed the McLaren F1.
Hey leeman, i did recognise it was you, took a second to click in that lovely work truck you were driving! lol! Would have given you more of a note if it wasnt for the slow car infront of me! And on other news i finally clicked over enough kms for full run in, so at this stage it will be back on the dyno next week for max power tune! :P
Yeah thought it was you but with so much traffic didnt see you til last second, most skylines i see going down happy valley drive just do the stare so ive stopped waving. Still gotta catch up sometime and get all south people together
Hey bud... so you're back from your hols in Asia then :) Hope you had a great time.
No i was planning to go later in the year not now bud.
Yeah .. that wasn't my ride... different plates and i wasn't down findon road.
Saw HOSTILE today at the On The Run on South Road washing his car, i dont know if you saw me i was the guy with the black 33 washing my car a couple of bays over, although i didnt get a good look at your it sounded tough as :cheers:
Spotted HR32, Maroone R32 GTST with a nice set of wheels that look perfect under the guards. Seacombe road this afternoon, I was in the red dungadoor VN with a new mech diff in the boot. :cheers:
Was Adam driving? Said he was gonna sell it ages ago....
He was part of organising the cruise down to victor
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
