Hi all,
I was wondering if any one could possible shed some light on an issue I've recently discovered. Not sure if it's an issue or normal behaviour.
I've got an 09 GTR totally stock accept a willall mid pipe. I've taken it out for a burst, and once i got it up to temp I have gone to boost out of a corner in second gear it's bogged down or like cut out straight away at a low RPM just as the turbos are spooling up. The traction control light flashes but I haven't noticed any wheel spin. I tried it again and It did it again, and then after that it spooled as normal with no issues. I'm hoping that maybe the tires were cold and traction control kicked in, but I'm not sure. Tires have only done 3k so plenty of meat left...
Has any one else noticed this cutting out ever with their GTR?
Could it be just cold tires, or maybe something more sinister.
Any advice would be appreciated. Cars still under warranty for not long so if it's a warranty issue I need to get it back Asap
cheers
https://www.sau.com.au/forums/topic/397195-r35-cutting-out/
It sounds like traction control / cold tyres etc. I've had this many times (with VDC on) well before you can detect actual wheelspin yourself. One way to test it would be to turn off VDC and take it for a spin again. My bet it doesn't happen, but wheel spins instead.
https://www.sau.com.au/forums/topic/397195-r35-cutting-out/#findComment-6306825
Lol you guys talking about auto and manual mode.
It's all auto.
LOL auto? Obviously you havn't driven one yet, it's the most amazing supercar on the market. Auto's have a torque converter this has none. It runs a clutch similar to the old school method times 2 and it's the speed of the shift that makes all the difference!
*flame on, Johnny cash
https://www.sau.com.au/forums/topic/397195-r35-cutting-out/#findComment-6314048
https://www.sau.com.au/forums/topic/397195-r35-cutting-out/#findComment-6314131
It's all auto.
When it's written on the shifter Auto and Manual mode how else are you going to describe it to someone. The characteristics of the vehicle change dramatically when shifted to each mode. Its a Auto when in Auto mode and its a manual with no foot operated clutch when in Manual mode. If you can convince me that a manual is not a manual unless it has a clutch pedal then its not a manual.
Edited by g35me
https://www.sau.com.au/forums/topic/397195-r35-cutting-out/#findComment-6319416
I lol'd.
No shit brainiac
Sorry did I touch a nerve?
Hmmm... how about hey Im in auto, and then hey Im in sports auto. Goin all manual without my gear selector nor clutch.
You guys bit too easy. Im not challenging the size of your penis, Im just saying dont think for you have a manual car because it says so. Shit I can go and put a GTR badge on my cat, still wont make her flutter!
Edited by eat_me
https://www.sau.com.au/forums/topic/397195-r35-cutting-out/#findComment-6319538
Thanks for the tip.. So actually my car is an Auto?? Who would a thought, all this time ive been driving my car in manual mode I didnt have to use my left foot to push the clutch... So what was I pushing?? The brake?? fark me that explains the problem with the car cutting out.. Thanks for your immense wisdom in clarifying the issue. Much appreciated.
https://www.sau.com.au/forums/topic/397195-r35-cutting-out/#findComment-6319705
Shit man, you must go back to driving school if you were doing that!
Haha, dont get so sensitive. Just take a breath and realise that Im right and your wrong.
https://www.sau.com.au/forums/topic/397195-r35-cutting-out/#findComment-6319948
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
