joe blo Posted April 11, 2012 Share Posted April 11, 2012 (edited) hi mates. just got a question about my setup. its na pistons and the head has been skimmed i rekn atleast 3 times. i had it done twice (after i got the head rebuilt then had to do it again after welded the bit for conversion), and i rekn the guy i got the head off may have skimmed it coz he had used it on a conversion also. how much would 2 or 3 head skims raise the compression? and i got the bottomend rebuilt. has na replacement pistons. shud they sit level with the top of the block on the outer rim of the piston? i believe mine do. reason i ask about this is my last setup broke 4 out of 6 ringlands and doesnt show signs of leaning out. guy says its too much compression. but he also says the rb25 head on 30 bottomend RAISES the compression. but it doesnt hey? rekns id be about 11:1 with his idea that it raises the compression and something like 16:1 on boost so just wanna see if the head skims and decking the block ( i assumed it only got skimmed to make it perfectly flat again) would cause me compression issues. ive already bolted the head on again and am about to get it tuned again by different place. havent checked compression. was just going off the guide thinking it wud be 8.2:1 plus abit extra from the head skimming thanks mates Edited April 11, 2012 by joe blo Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/ Share on other sites More sharing options...
Gerg_R31 Posted April 11, 2012 Share Posted April 11, 2012 http://www.skylinesaustralia.com/forums/topic/378823-engine-internals-comp-ratios-general-info/page__fromsearch__1 that is a link to some info i wrote up a while ago, it has the correct formular to work out your static compression ratio as the rb heads have a tappered chamber, and how much was taken off each time it was ground will vary or "how long is a piece of string?" Do a compression test and post the results, some forum users on here may be able to tell you a rough area on where your comp ratio is with that for my motor 10.75:1 i get 225-230psi dry comp 240 wet comp test Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-6311203 Share on other sites More sharing options...
The Mafia Posted April 11, 2012 Share Posted April 11, 2012 8.2:1 is a standard NA RB30E block and RB25DET head. With 20 thou taken off mine was estimated to be 8.35:1 So with 60thou taken off I'm estimating around the 8.65:1 mark. But this is a very avergage estimation. I'm assuming with tapered chambers etc the more you take off the greater it goes up. But, I am sure that you compression will be well under 9:1. The reason your have blown your ring lands off 4 pistons, is because of the tune, and driver abuse. I'd even put money on that. Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-6311287 Share on other sites More sharing options...
r33_racer Posted April 11, 2012 Share Posted April 11, 2012 Measure your piston protrusion, cc your chambers, then do all the maths....dont bother guessing when its not that hard to do it properly. Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-6311387 Share on other sites More sharing options...
KiwiRS4T Posted April 15, 2012 Share Posted April 15, 2012 http://www.skylinesa...__fromsearch__1 Do a compression test and post the results, some forum users on here may be able to tell you a rough area on where your comp ratio is with that for my motor 10.75:1 i get 225-230psi dry comp 240 wet comp test OK well the compressions for my RB30/25 are all around 132psi so has anyone got a similar engine with a known CR to compare ( I would guess about 8:1 but its not that important now)? For reasons too boring to relate my budget engine had dodgy pistons replaced with some good cond but evidently less than ideal pistons that were available at the time. Consequently its only making 230awkw (with a GT3540) at 15 psi instead of nearer 300. I have just done a leakdown test - all between 5 and 8% so I will wind the boost up as much as possible with a new tune and live with whatever power it makes until I can afford a rebore with 9:1 pistons. Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-6315975 Share on other sites More sharing options...
The Mafia Posted April 16, 2012 Share Posted April 16, 2012 At 8.2:1 I got 155psi per cylinder. What sort of gauge are you using? Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-6316584 Share on other sites More sharing options...
XKLABA Posted April 16, 2012 Share Posted April 16, 2012 just a quick Q, wouldn't a comp test give you dynamic comp ratio and not static? Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-6316900 Share on other sites More sharing options...
KiwiRS4T Posted April 16, 2012 Share Posted April 16, 2012 At 8.2:1 I got 155psi per cylinder. What sort of gauge are you using? At 8.2:1 I got 155psi per cylinder. What sort of gauge are you using? At 8.2:1 I got 155psi per cylinder. Just the handheld compression gauge I bought many years ago - the tuner got the same figure with whatever he was using What sort of gauge are you using? just a quick Q, wouldn't a comp test give you dynamic comp ratio and not static? Comp test doesn't really give you a compression ratio just wanted to compare with someone who did actually know his compression ratio and also the psi. The two tests gave me the answers I was seeking - the leak down test is ok so the motor is basically sound and the low compressions are the product of the choice of pistons, head gasket and head with the main culprit being the pistons so as above I iwll just make the best of what I have with the best tune possible until I can afford new pistons, balance etc ...probably a year or two away! Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-6317311 Share on other sites More sharing options...
KiwiRS4T Posted April 16, 2012 Share Posted April 16, 2012 Clearly haven't got the hang of "multiple quotes " yet but the answers are in there somewhere! 1 Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-6317312 Share on other sites More sharing options...
r33_racer Posted April 16, 2012 Share Posted April 16, 2012 I would think everyones different camshafts would mess with your comp readings from engine to engine. Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-6317514 Share on other sites More sharing options...
MRHD66 Posted May 30, 2012 Share Posted May 30, 2012 (edited) I would think everyones different camshafts would mess with your comp readings from engine to engine. ^id have to agree with this comment ^ Edited May 30, 2012 by MRHD66 Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-6378208 Share on other sites More sharing options...
Simon-S14 Posted June 21, 2012 Share Posted June 21, 2012 What's the cr with a 26 head and na pistons? Same? Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-6410615 Share on other sites More sharing options...
joe blo Posted June 22, 2012 Author Share Posted June 22, 2012 bit lower Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-6410770 Share on other sites More sharing options...
AngryRB Posted May 7, 2015 Share Posted May 7, 2015 What would be the highest compression you can get with RB30 stock bottom end and a neo head? has anyone achieved 10:1 or higher with say a 0.8mm head gasket and shaving the head, how much can it be shaved? I wanna get the maximum out of the combo, as in area under curve for the street... Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-7529983 Share on other sites More sharing options...
KiwiRS4T Posted May 7, 2015 Share Posted May 7, 2015 What would be the highest compression you can get with RB30 stock bottom end and a neo head? has anyone achieved 10:1 or higher with say a 0.8mm head gasket and shaving the head, how much can it be shaved? I wanna get the maximum out of the combo, as in area under curve for the street... Have a search - someone built a very high compression N/A RB30 a while ago. Found it already - its back in this thread^^ Gerg_31 got 10.75:1 Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-7530012 Share on other sites More sharing options...
AngryRB Posted May 7, 2015 Share Posted May 7, 2015 (edited) maybe I should be more specific, I want to get 10:1 compression ( 200plus psi on a comp test) or very close, what gasket and shaving is required ? pretty sure the 10.75:1 was from a 3.2 stroker 26/30.. Edited May 7, 2015 by AngryRB Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-7530022 Share on other sites More sharing options...
zebra Posted May 7, 2015 Share Posted May 7, 2015 200psi on a comp test only means you have small cams Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-7530027 Share on other sites More sharing options...
AngryRB Posted May 7, 2015 Share Posted May 7, 2015 That was just to give an idea, it will get the drop in tomei cams down the track but when you have a good RB30 stock block and a neo head, what do you suggest to get every drop of torque under the curve from the block and head combo, so hence comp and quench area, im sure a lot of guys will be interested in this... Link to comment https://www.sau.com.au/forums/topic/397525-rb25-30-compression-na-pistons-head-skimmed-couple-o-times/#findComment-7530030 Share on other sites More sharing options...
