  • Replies 42
I made 260kw at 15psi so never 100% injector duty.
Injector duty is around 88-92%.(depends on AFR)
Does someone want to explain to me how thats possible?
Im making 290rwkw with 500cc and it 77% duty...
going by the above statement I could run E85 on my 500cc injectors and get more power... wtf...
PLEASE don't! :P
please do!
it's not possible under normal circumstances. unless your running wmi or something similar anything more than ~200rwkw on standard injectors is either running lean or is just a happy dyno.
please do!
Happy by 60 rwkw?
Standard injectors are 370cc, which i've been told makes them good for 370 crank HP at 100% duty and standard pressure, or there abouts? So in theory, the 400-450 crank HP Toshi is making would need %15-%25 more pressure to keep them below %90 duty?
Is that right, or am I missing something? Also interested in this.
Defently not the dyno, it reads within 3kw of factory spec on new cars that have been run up, maybe ive just got a freak 25? oh btw my vvt isnt connected =/ but that only affects mid =)
Edited by 51NNA
correct its also a dyno dynamics, my tune was done at 11pm on a winters night so it was getting nice freezing air, doubt it would make the same power in summer.
Edited by 51NNA
no...were did you get that idea from? LOL there is a setting that shows flywheel power but its defently RWKW, i dont understand why you think its so hard for a rb25 too make 200rwkw, my rb20 stock on 1bar was making 180RWKW...
Edited by 51NNA
Youll find most will say HP and RWHP these days, the tests were done on stock WRX's, when i worked there we mainly did wrx's because of the AWD dyno..and most of the time people would complain our dyno showed a low reading compared too others.
Edited by 51NNA
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
