So last night went to start the gtr and she had a dead battery, as I only drive it on the weekend it spends most of its time in the shed with the alarm slowly draining her.
So my question is wher can I buy a decent battery at a good price south of the city? Battery is located in the boot for those that don't know and its pretty compact too
Thanks in advance jarad
https://www.sau.com.au/forums/topic/397627-car-battery/
Hey Jarad - Maybe try battery world and then stop by supercheap and buy a cheap SCA battery charger.
If you have a garage back it in and connect the charger, put it on trickle. (take the leads off the battery first)
Bazzinga ! - no more problemo
Ps. Battery's dont last long if they discharge fully multiple times.
https://www.sau.com.au/forums/topic/397627-car-battery/#findComment-6312753
Buy a yellowtop Optima deep cycle battery. They're more expensive than std batteries but they can withstand full discharges and often retain charge longer than a lead acid battery. They're also sealed so they're well suited to boot mounting.
Had mine for 4 years, never skips a beat. Sometimes needs a trickle charge to top up when I do loads of short stop start trips but its worth the cash
-D
https://www.sau.com.au/forums/topic/397627-car-battery/#findComment-6312824
Odessy battery
Yellow top
A few other brands but they're hard to find and cost more
Defect to use anything but sealed without proper venting and you will be happy with the above
my old yellow top lasted 11 years and that was in a area it snowed and got to 40+ , shame the markup is so high in oz the new lithuim batteries are beasts , ..... new cars wont be 12v in the very near future (most likely 48v lithium ion)
watch out where you buy battery even a well know shop down south has grey market imported battery NOT covered by any usa or oz warranty
And its one battery on the above list , also note a special charger is needed to charge the above if they go flat , the standard chargers wont cut it, even a high power floor standing model wont ,
if the alarm is draining your battery in a week your siren backup battery is prob 2-3 years old and will eat your car battery even after you change it out , those siren batteries can get funny about the 3 year mark or if the get run flat a few times( car battery goes flat as well) a daily driver car siren lasts 6-10 years , stored cars 1-4 years tops
upgrade your factory charge wires and grounds and terminals when you do the battery to save you doing it twice !! Use full size car audio terminals dont mess with the crappy car parts ones !! Plus they look nice and have covers
Factory size (small)batteries are not up to the job if you run a stereo amp and modded car , the little jap ones are junk , just enough to start the car not much else
If you redo the wires car audio wire exceeds the looks ,performance and much cheaper in kit form them premade wires
Dont use arc welding wire its too stiff and connections are hard for home users to do
My 2 cents
https://www.sau.com.au/forums/topic/397627-car-battery/#findComment-6313029
Hey luke check out the new lithium ion batteries from usa ,
http://www.braillebattery.com/index.php/batteries/ml7s/#
Just starting battery ? Dont forget 6 coilpacks take a bunch of power and a couple fuel pumps
you want a buffer so you dont trash a motor due to low voltage on the ecu , coilpack, fuel pumps and electric fans if equip'd .. Anything below 12v and enough current available and malfunctions occur , my old commy would start shutting down the ecu at idle when the bass hit (1 amp only) gulping power 90amps at a time with just normal stuff turned on inside the car , it ended up taking a coil pack and alternator out
What I'm saying is even a
Full time racecar needs juice and grounds beyond factory
The battery on the link is the lightest you can buy but you might want a bit bigger version of it
and you still need the cable and connections but the only 4ga needed in a race car is starter and ground on battery to frame and engine alternator bracket
The rest 8 ga is fine
https://www.sau.com.au/forums/topic/397627-car-battery/#findComment-6313484
Odessy batteries are all orange unless its military version , some have metal jackets for offroad protection
Red top is starting only , light aftermarket stereo
Yellow top - dual duty start and some ability to deep cycle without damage
Blue top - deep cycle boat or rv battery can be recharged and cycled many times with proper charger
A cheap option is a UPS battery like the big jaycar one but you must have good connections and go for long drives to charge weekly , not light but 100% sealed
When you do a new battery get a chunk of rubber from clark rubber about same size as battery and a chunk for bracket touch points , about 5 mm i think it is
It will save every battery from excessive vibrations that dead short the plates inside and extend the life dramatically
https://www.sau.com.au/forums/topic/397627-car-battery/#findComment-6313497
All good info Troy.
I need something better for the bike as it doesn't have compression releases on each cylinder and as a consequence it eats batteries regularly.
Modifying for compression releases costs way too much so I'm thinking that there might be a battery from the link you gave to Luke that may last a little longer....ideas??
https://www.sau.com.au/forums/topic/397627-car-battery/#findComment-6313541
Something in lithuim ion pete , it takes a continuus draw pretty well and the weight wont affect the bikes center of gravity so much and nonspill bonus , what compression is the hog ? 12.1 or more ?
Guess a lawnmower pull start might rip your arm off and a kickstart would gut your calf on recoil
Just remember its like a mobile phone or laptop deep cycle it a few times then charge full ,
Deep cycle about once every few months to stop memory from building up in the battery
a charger for these batteries is mandatory to do that properly not a supercheap special
just watch out these come in 12,14,16,18 volt and more
14v isnt better in a 12v charging system and can fry headlight ballasts , all the ecu's , and lcd screen and traces on boards
those are strickly for cars wired to isolate the car from that battery and charger ( big car stereo systems )
and since its battery questions
Batteries in parralel add current capability voltage stays the same ( positive to positive, negative to negative) must use same battery and same age or it can be dangerous , this is 12v still but batteries need isolators to charge on stock alternator without killing it ( battery in boot and one in bonnet area, otherwise you can strap together and charge as one)
In series the voltage goes up , current can drop from resistance ( positive to neg of next battery , ground off the first one to ground, positive of second battery to car) this is 24 v in cars trucks
All kinds of worthless crap in my head lol
https://www.sau.com.au/forums/topic/397627-car-battery/#findComment-6313620
Hahaha, with over 800cc per cyl at hi-comp, I'd have a peg leg in no time......or a calf the size of Nightcrawler's thighs :whistling:
Thanks for the info bud, I'll def look into lithuim ion units next time the bike eats a battery
https://www.sau.com.au/forums/topic/397627-car-battery/#findComment-6313985
-D
+1 also a jump back in the boot never goes astray
https://www.sau.com.au/forums/topic/397627-car-battery/#findComment-6318150
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
