Hey; After two years it's time to replace the brake pads;
I've been in contact with Queensland friction materials they just want to know what type of calipers i have; to which i replied I think they are standard Sumitomo's; to which they replied Yeah but what type?
No frackin idea.
Here's a picture.
https://www.sau.com.au/forums/topic/397650-what-brake-calipers-are-on-34s/
Love the sarcasm/cynasism lol
Well the guy i've been talking to is quite knowledgeable about this sort of thing; i'm obviously not.
And there's actually a very good report on these very forums with these QFM Brake pads for street use
When you look at it from his point of view; I know there are many weird upgrades for certain models- Some of the skylines have Brembo brake calipers !!??
The numbers he gave me were showed he thinks they are either DB1170 or DB1220
I've checked my R34 manual; as usual it is completely useless except for showing how to top up the washer fluids.
You don't need to take te pads out it is common knowledge what pads they use, obviously old mate at Qfmdoesn't know skylines
If you tell Greg at Gsl you need pads for r34 gtt he will know what pads you need, I should know as I've bought pads off him for my r34 gtt last year and for my r32 before that
Thanks guys, and yep we can do both QFM and Remsa (and 12 other brands of pads), and carry heaps in stock ot sit GTT.
Your problem in dealding direct with QFM is that they're a manufacturer, not a distributor, so they don't have the real world experience of knowing what's what. They know part number and how to make them, and limited vehicle specific knowledge. For this reason most of their performance pad inquiries just get forwarded straight to us to answer.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
