Plus another 200 CC Mark :P.
Was out there again today. Another few little things crossed off the list. Boys have been snowed under. Yavuz reckons fire up Tuesday or Wednesday. Wahoo!
You've got 12 days left!
This is true.
On a side note, I dont think I will have time (read:UNIGROUP) to hook up launch control, so all the cheater AWD vehicles may have a slight advantage at the NATS.
Im drunk, punch me in the face, I deserve it...................
Horse power is how hard you hit the wall. Torque is how far you drag it behind you.
This is true.
I reckon you'd be hard pressed to get that done. You got tyres sorted? When you going E85 farken?
Tyres = M/T Street Radials
E85= When Caltex (or any other supplier) have it in every servo, like they said they would in 2010 :verymad:
Sensor mate. This issue no longer exists. It's getting there. You have the powah with the Link ;).
Ive been a bit scared off with the sensor, Ive heard (google farkin) there has been a bad batch of them giving iffy readings, Ill give it 12 months and if it seems that the issues are sorted then Ill go in balls and all.
All I need is the sensor thingie, injectors, fuel pumps, lines and tune, and around 3-4k of loose change.
And I still need to get the Link tuned for PSI Vs road speed, gotta love the Link.
Went out today and lent a little hand. Brakes are bled, all belts are on and intake piping on the passenger side is on. Exhaust is on, fuel system changes are almost complete (I've moved the ethanol sensor into the boot so it's not in the engine bay).
Almost complete bay.
It's voluptuous behind with the "standard" exhaust.
Well mine's on the road :D
Put 270km on it, running it in.
Tune is next.
You're a machine!!!!
My start up is today with anyluck. Check for leaks, timing and onto the rollers. :D
That's three white GTRs I know of racing to get back on the road!!!
Looking good paul
Mine fired up in the garage last night. Bleed the 4wd, change of rims and few vac line tidies and I'm ready for a tune. Paul, get your beast out of Unigroup so they can tune mine! :domokun::nyaanyaa:
Haha I'm trying!!! I'll hopefully be doing skidz this arvo. Did you drive it Eric? Any idea what your goals are? Where are you gonna limit boost? 260 poncams?
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
