its ok pauly, i know how good your massages are. Ignore all these haters, they be jealous baby. Ps. Tell yavuz ily. You at the races on cans?
Yeah man, down at the F1. 8 of us. :D
Car got ran up yesterday with new injectors. Negative. Yavuz has pulled 35% of charge time from the coils and it still fires so that rules that out. Going to try new plugs with mega small gaps to totally rule that out then we will change springs.
Well it doesn't leave too many things it can be now . Just hope it is a plug problem , quick & easy in comparison to a spring swap .
Btw , what plugs are you running? Coppers or an electrode-less type .
I have a feeling it could be a sticky spring with these cams mate. Have they checked for bind and the progressive spring tension? With the ramp on the valve train it is a likely cause.
Seat pressures are 48 lbs on the intake and 50 on the exhaust. Not much over standard which is a bit of a shit go considering these are "Step 2" HKS. Once again, the Jap stuff is mild as!!!
Just coppers mate.
All I can say to you Paul is that I hope you fix this soon because tomorrow is F1 race day. So get a few (or lot brewskis) into ya and forget about tuning the car right now.
And yes im on to my third beer and life is good.
Bit hard when you're staying with your tuner ;). As for beer count... Not sure. 12 plus so far? Quiet night... Big night will be tomorrow haha
Should be more like almost double those figures for the sort of rpm/boost you would be running. Like around 80-90 lbs. Perhaps with your new aggressive valve train/cam setup the valve springs were not spec'd correctly and your getting some valve float in that upper rpm range.
We think that's exactly what's happening. I spoke to Yavuz today and when we are both sober we will sit down and talk about what we need. We also need to factor in the new cam we are going to try soon. Something around 255 @ 11.3 with a HUGE ramp, so we need a spring to be able to close the valve at high RPM.
  • Like 1
Well it seems like the logical explanation. There doesn't really seem to be too many other obvious options left that explain the problem.
Definitely sounds that way. I'll be devastated if we change then and this issue is still there.
Mine's do cams of similar spec if I remember correctly
OK guys.
I was out at Unigroup today. New (stiffer) valve springs have been ordered. They will be here on Tuesday, hopefully installed on Tuesday/Wednesday. Yavuz wasn't there so I dont know the details but i'm sure they are more than sufficient for the task!
Now. I have some overlays
408E824D-9A03-4A70-BD6E-5B1528A30784-158
This graph is the only two runs we have done with the boost controller on so it's hardly 'optimised'. We did those two runs with the controller on when we were trying to diagnose the "miss". Funnily enough the curve starts to flatten off as soon is it does it's thing. Either way, im very happy with the midrange this thing is putting out! (No cm timing has been played with yet.... It's as the engine got put together. Also, at 19 PSI we have seen 417 rwkw. I can't remember what RPM that was at. I forgot to get a graph of that run)
5398CC6B-5BAC-4962-A3A5-4704EA38B086-158
Playing with the computer, I dug out these two graphs for a comparison. The black line is my first ever tune with the GT-RS's on pump fuel and the red line is my finished tune just before the engine died last year. Funnily enough, the boost controller was turned ON with the RS's and OFF with the -5's. Haha!
I think I need new tyres! :D
7DCAA74A-93E3-4813-B58E-41F4AC719280-158
wow! looks like a gain of 50kw @ 4krpm!
must be happy & must be hanging to drive it
so with the gtrs's u were making 200kw @ 4krpm & now you are making ~340kw with -5s & latest setup :)
what is the difference in the run with the blue line v's the brown line (in the 1st graph) or is it just 2 runs where you were trying to diagnose the miss?
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
