haha!
$3600. Otomoto want $4,500. Fair deal!4/5 gears work, that's fair :P
But the OS 3 speed kit from RHD is only $2000 & the 5 speed kit is $2400…I don't see the limited edition 4 speed kit like the one you have though. :rofl:
But the OS 3 speed kit from RHD is only $2000 & the 5 speed kit is $2400I don't see the limited edition 4 speed kit like the one you have though. :rofl:
Haha. It's really good. ITs just a REALLY tall 2nd 3rd and 4th. 5 gears are crap, although you really need a torquey engine. :P
Just put an OS88 into the car …you know you want to , there only 14k landed from RHD.
At least its rated to 1500hp unlike the PPG.
Downside=cost , and who the fark wants to service the thing every 5000kms.
Why can't someone manufacture a damn box rated to 1200hp or so , that can drive like the stock box, no ridiculous service intervals, without needing a kidney donation to fund it. :/
Edited by ezy_09s
14k is getting up there. If u could a second hand stock box for $700, u could go thru 20 of these...what a great option :)
Wouldn't be so bad if only took ten minutes to swap them out.
Just put an OS88 into the car you know you want to , there only 14k landed from RHD.
I couldn't a agree more. There is a HUGE gap in the market. Not everyone wants sequentials but they have the power to warrant a bulldog box.
Let's see how this dog box is. Can't be that bloody hard!
What I am having troubles with is a clutch to accept the larger spline. I rung Jim berry and asked if he could modify one if I sent him a brand new coppermix. He wasn't sure. Took my number down and is going to get back to me.
Suggestions?
Suggestions?
Cant be that difficult to have your clutch plate modified to suit the larger spline shaft & reuse your nismo pressure plate.
Have you tried John at Western clutch at St Marys..he might be able to sort you out as well.
Did PPG recommend any particular clutch when using the large input ?
Maybe you can email them a picture of the centre boss of the hub & just say to mod the centre to accept the large spline .
http://www.rhdjapan.com/nismo-super-coppermix-center-boss-hub.html
Edited by ezy_09s
Apparently it is. Something to do with the type of twin they are.
No recommendation. I really don't want to move away from it though. My one has been in the car for 9 years. Don't care if I have to buy a new one, but it works and drives awesome.
I would take the centre boss of the clutch apart and get the splined drive out of it & find a shop who will machine the identical part but with the spline size you require.
This is the problem.
I don't want any downtime. If I buy a new coppermix and can't get it done then I'm rooted.
Time to keep calling around I think.
You don't need to buy a whole new coppermix ..you can buy the new centre boss for $275 & new clutch plates for $228 from RHD .
http://www.rhdjapan.com/nismo-super-coppermix-twin-plate-clutch-replacement-disc.html
If someone can't machine a new splined drive with a cnc machine then they need shooting.
Edited by ezy_09s
Do you know what size & spline count the large shaft is ?..i can't find the info on ppg's site .
I wonder what ppg would charge to make another centre drive to suit their shaft if you supplied the original nismo unit to them ?..it wouldnt hurt to ask if they would or could do it since your willing to drop a bunch of cash on their gear sets.
Edited by ezy_09s
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
