looking for some feed back/opinions on these wastegates................as ive always run the old school garrett 32mm and 42mm gates............never used tial or turbosmart gates before........i have 2 38mm mvs gates and 2 45mm hypergates
any info be a real help
Edited by stocker
im not interested in sizes i know how gate work the smalller the gate the less gas it let 'sso theres more gas to spin the turbine ie high boost and big gate let out more gas for less turbine speed ie low boost ...........im more interested how they perform,hold boost,longevity of the gate in question,issues with the two brands etc
Both are very high quality gates. I havent ha a gate "wear out" only the cheap evay gates are a little dodgy as the valves dont seat 100% and theres too much play in the valve guide
Not sure bout turbosmart but the Tial allows coolant to run thru the top, does anyone run coolant thru or not worth it?
Ive been told all the Tials are just cheaply made in china? is this right or are they made in US?
i was planning on running the coolant if i end up using the tials
hi you find the real tials are us made but there are a whole heap of china tial knock off getting about.................before you buy a tial gate get the s/n and email it ti tial they tell you if its legit or not ...............but funny thing is turbosmart are made in china or what ever,yrs ago turbosmart use to have a hughe yearly sale of 2nds at wetherill park..........but there moved there manufacturing plants o/s
wtf happened there?
lol, well personally i think the Tial looks the goods, i have a 44mm Tial and its a large unit, looks pretty hardcore compared to turbo smart. I havnt seen it work yet though and a newbee with this :whistling:
Yep, we have a Tial 38mm running straight off a turbo housing in a low mount application...which would get mega hot compared to having it off the manifold at the collector. It runs the coolant through it and the boost curve is straighter than a ruler.
Under racing conditions where everything gets super hot and the metals and welding are under most strain, the coolant helps lower temps down and prolong the life of the wastegate. The diaphram's life will be extended, as rubber perishes from heat over time.
I prefer TIAL gates as weve had ONE genuine TS gate jam. Theyre both good designs and nice and compact. The feature of the coolant cooling is favourable if youre racing it, but whether you have room for the lines (assuming twin scroll since youre using 2) or not is another thing to consider.
i got a 2jzgte aristo champ i would run them off the top water neck i would just get some alloy weld on 3/8th bungs to feed the gates the cool coolant and feed them back in to the alloy radiator to cool the colant exiting the gates opinions ?
i got some hks 2jzgte twin turbo manifolds with t3 flanges welded to them works out good for my twin td06's........is that a bad idea to feed the hot coolant out of the gates into the turbo'sor vise versa blake...............ive hidden the fusebox in the clovebox etc,deleted alot of stuff..........blake is going to be welding me in a custom tunnel
Edited by stocker
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
