Why is that Alex? Its only dumping 10-15 degrees of timing for 3 seconds or so. Should be interesting to see the flames, lol.
I have to get this barge off the line somehow. Craig sent me this link...
I just love seeing the stuff you come up with and actually get to work. It sure needs a hand to get off the line, maybe an extra litre would help :P
I have to slow my response down low...
No exhaust just poked the dump pipe, yerh foot to the floor.
But I can't understand y I'm stuck at 2200rpms when im trying to stall it up? Shouldn't it let me go beyond?
Not with a 2200 rev stall converter. If you want it to take off hard you went too big with your turbo, now you have to match the stally to the lag you bought yourself. Mine is a 3000 stall converter and it may be for sale soon. I will probably be heading for 3500 stall with 6 lockup clutches instead if 1. (if Kewish can sort me out with one...)
anti lag? you did not tell me of this scott :P
Cihan and I were talking about it, seeing I don't want to go too big with the stall converter and I don't want to spool the turbo with NOS I have very little choice at the moment.
Yes Alex, the 3.5 will help but that isnt getting a plain rebuild, if I ever get the funds I will be shooting for big numbers, too big for a Stagea to handle I believe. ;)
is this wire cut mod only limited to turbo stag's? what about v35s?
I have no idea, I would assume there is something similar in their ecu. Do you have a link to the ECU pinouts? I will have a look if you can find it...
I don't think that the V35/PM35/z33 throttle restriction is based off the same process as the NM35.
I believe its more of a electronic throttle table, that will only allow a specific percentage (or volts to be precise) of throttle opening at X load Y RPM. Not based off the brake signal as far as I can tell. I base this off the fact that I can alter the values in my tuning software. Anyone who has driven both cars will realise the difference.
No pic.
The VQ25dd ecu uses the same plug as the VQ25det so it should be similar but without the pinouts youre flying blind. I have the full M35 electrical book in front of me but I can't read Japanese...
I too can adjust the throttle sensitivity but the restriction is different, have you hooked up the software to see if you get 100%tps at stall? Perhaps its gone now with the re-flash?
yeah ive only got a jap version too
some v35s come with the factory snow/power switch that does the same throttle reduction/increase in sensitivity. i keep mine on snow 99% of the time but it has shown no improvement in economy... still 12.6L/100km
Snow will take off in second usually although I haven't played with the switch much in mine.
each car is different obviously, in my case it still uses first, throttle response appears to be around 10% of normal, revs stay below 2500rpm, and no kickback.
Wat?
So, you put it in snow 99% of the time, but it doesn't improve economy, so in essence your driving around a car that feels like shit for no benefit! I see no point!
The one and only time I use snow is when I'm putting the car up on ramps- because it locks front /rear torque. It will just drive up the ramp easy (obviously you don't have awd...)
Scotty, I haven't done a throttle % map, and it is different now. I have a completely different ecu, even to most of the V35's, as its a Gen 2 Ecu- Runs widebands not narrowbands from factory. But there is just no way there is the NM35 style restriction on our Ecus- stock, there isn't the torque of the turbo motor!
Wat?
i only just calculated the economy after noticing the factory economy meter hadnt dropped....
using the switch is now just to make takeoff alot smoother... as the pedal is way too sensitive on the other settings.
As Scott said its due to the stock stall converter. Should work fine for the stock turbo....well it works great on my setup...
oh ok just realised you had a 3071...hmmm yeah no boost for you LOL
  • 1 year later...
The pedal is way to sensitive....grow a set! This is a V6 not a nissan micra. Get over it or get another car
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
