Yeah I would love to see how Ant's yellow paint comes up from behind Matt's camera.
Mate are you going to leave the eyelids on do you reckon? I took mine off, they were good quality ABS plastic though
It will get behind Matt's camera I'm sure one day, probably when the cars a little more finished though at this stage...
The eye lids, tbh it has never bought enough attention to me to really have a good think about it (strange, as I believe the attention to detail on my car is beyond obsession, hence why the car is back at the painters again working on the bonnet ha)... Im not even 100% certain what they are, they look like nismo ones, and I like the style of them far greater than other r34 eyelids I have seen as they aren't very aggressive... But im not really privvy to what's out there either in the way of them, just not something i have really looked into.. So yea at the moment they are staying, if they didn't come with the car, I highly doubt I would have bought some, but looking at them doesnt make me what to take them off... Abit weird as there not really my Thing, but oh well... Was thinking the same with the te37sl stickers I have too.... Tough decisions haha
  • Replies 110
Its pretty nice looking but If yu scroll back a page or two you'll see its to similar to the last car shot. Any specs? Pretty sure the 99% of thread will want to know whats In It.
Thanks Matt,
Pretty much the i bought the car as a standard Vspec and then added a few bolt on mods,
The specs are as follows:
Aragusto Coilovers
TE37SL 19x10.5
Nismo Skirts and rear aprons
Tinted front and rear indicators
Yokohama 19 x 275 rubber
Tomei 260 Pon Cams
Trust Cam Gears
Nismo Fuel Pump
Sard RZ fuel reg
Split fire coil packs
Cusco Brake stopper
Haltech Platnium Pro Computer tuned to 260 at all fours for now
N1 Water pump
120mm Cooler
3.5 inch custom Exhaust and front pipes
ORC Twin Plate Carbon Pro Clutch
Theres a few other things I left out probably.
Other things to be installed on the car which I have been lazy to get done but are
sitting on my shelf
Garret 2860-5s
Tomei Dump Pipes
Sard 800cc injectors
HKS Kansai Brace
and re tune
The car runs on royal purple and motul fluids and gets serviced every 3000km
and never leaves the garage if its raining or windy lol too paranoid of a branch falling on it,
if anyone wants to know anything more feel free to PM me =)
Cheers
Garth
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
