R34 GTR V-spec, lightly modified 260kw@wheels priced to sell, cheapest V-spec around, with a few tasteful mods
- Factory wheels paint charcol
- HKS coilovers
- HKS air filters
- Spit fire coil packs
- Apexi power FC with hand controller
- Apexi elec boost controller
- OS Giken race twin plate clutch put in about 2000kms ago
- Jasma front pipes into 3' hi-flow cat into 3 1/2' rear pipe
- Autometer boost gauge
- Nismo 320km/h dash
- TV/DVD player
- Viper alarm with pager
Car has been tuned on 14-15psi making 260kw@rw
Great weekender, amazing car to drive, first to see will buy
Car is located in Mill Park
Any questions just call Billy 0404 00 66 00
$45000 ono MUST SELL money going back into business
Very regretful sale
Edited by GXE747
  • 3 weeks later...
Quite reasonably priced I have to say - tight market.
Jap History with Logs? > Kms?
Are you the first Aust owner?
Service history here?
Can't help but feel that there's some other modification other than exhaust, hi flow cat and that psi to put out 260. Mostly, that setup would show about 230.
GLWS :)
GLWS :)
I recal seeing my friends dyno sheet for his R34 GTR reading out 253awkw with nothing more than a full exhaust and boost (ableit 17psi on ceramics lol). Still standard injectors, fuel pump, ecu, the works - same said car ran a 12.2 down the creek!
GL with the same mate, car looks very nice!
Thanx guys..
Terry_GT-R34 - thats all the car has. I took it to calder park and had 1 pass and ran 12.0 @ 115mph
I rekon better tyres, adjustment on the suspention and a better take off no probz a 11.8-11.7
A mate went 11.9@114 with just an exhaust, boost restrictor taken out and a twin plate with his r32 gtr
I am the second owner in Oz, car has 71,000kms, all factory books stamped and even the factory spare key still stapled in owners manual
As for service history here, my mate used to own PET modifications. He maintaines the car now out off a private garage
Any further questions please call Billy on 0404 00 66 00
Cheers
  • 4 weeks later...
  • 3 weeks later...
Thanx guys..
Cheers
dont believe ya
or i should be runnin 11.5 with -7s
Edited by w34ponGT
Thanx guys..
Cheers
I would believe a 260awkw 34 gtr run 12 flat. But R32 gtr with exhaust and no restrictor which means running 14-15psi doing high 11s is really hard to believe.
w34ponGT - According to the power your "claiming to have" your very far off the money champ
You say ur cars got 315rwkw but you could only get a 12.1 @ 118, so either ur car doesnt have that power or your not driving the car hard enough
What about a stock engine Gtr, cat back, 12psi running 12.18?
Why do people feel the need to ridicule someone who is trying to sell their car by posting rubbish in their threads,
If you really wanna see proof ask XKLABA, ran 11.3 with 290rwkw on stock turbos
So disappear and let the bloke sell his car
GLWS mate
GLWS mate
+1
Awsome car.
Free bump
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
