Hi guys,
I would appreciate some advice from experienced owners.
Basically i just purchased a Apexi PFC as a base for all mods I want to know if there is anything else i might as well do prior to getting the Pfc tuned.
I have a standard R33 minor mods list as follows.
Cat back exhaust
Front mount cooler
Boost controller
Im currently in the market for a Bell mouth dump pipe and front pipe and cat.
Should i bother with a bigger fuel pump or will standard cope with a higher boost setting?
As above said I want to know if there is anything else i might as well do prior to getting the Pfc tuned and squeezing the most Kilowatts out without swapping turbo as yet.
Any PFC Tuners people have had a good experience with I dont mind paying if the work is worth it?
  • new panel air filter for std airbox or pod enclosure with cold air feed
  • dump and front pipe a must
  • check coil packs for any visual damage or cracks
  • boost gauge if not running PFC boost kit
In regards to standard airbox ever since i installed the front mount i cant get the cold air snorkel back on the air box because of the top pipe so i bought a pod need to source enclosure
Make sure the fuel pressure is monitored while you are boosting it up and tuning. And be prepared to buy a new 040 or equivalent if the pump shows any sign of not being able to keep up. Don't wait for it to fail, but there's no need to spend the coin immediately if it is OK.
That said, if it is the original pump, then it is running on the borrowed time part of its life, so a pre-emptive change out is not silly.
Go find someone with identical mods, copy their map, go find a tuner and get the A/F ratios and ignition tidied up (if needed) so they charge you less.
So many times, I've seen people fork out up to $1k for a "so called" tune from scratch, when most of the time it's a copy and paste job.
I recommend you highflow the turbo before hitting the dyno. Your stock turbo is just going to f*ck out once you up the boost.
The following should be done and can be expected (not taking into consideration your current mods):
JJR bellmouth front/dump
3" highflow cat
3" cat back
Hypergear highflow turbo
FMIC
Walbro fuel pump
Provided all other aspects of the car are in good condition you should get 220-230rwkw without changing the stock injectors or AFM @ 15 psi.
I have read that the stock injectors are not as great above that pressure level and it is known that is already the limit of your stock AFM. Personally I would run the above setup if wanting a quick car not exceeding 250rwkw.
ok so 040 internal pump is a must cheers!
Definately change the pump.
Where are u located?
I'm located in Western Sydney
I haven't gotten a quote for a tune as yet. although saving money and tuning time would be ideal!! is this a difficult process copying maps is it as simple as changing settings via the controller
3" highflow cat
3" cat back
FMIC
Walbro fuel pump
The high-flow does have a nice ring to it i might have to wait an extra week to come up with more funds and look for one on the forum.
Dont mean to start a debate which fuel pump is better "Bosch 040" or Walbro 400lp both intank?
Thanks guys.
Hard to avoid starting a debate on that one. I went with the Bosch pump, mounted in tank it is the loudest thing in my car. But I'm reasonably confident it won't just up and shit itself. Walbros are quieter, but the internet derived failure statistics on them are not as comforting. Horses for courses there I'm afraid.
I dont mind Fuel pump noise lets me know its working at least.
you will need a FC Datalogit Kit, just borrow someone's kit, the rest is piss easy
If anyone can help me with this I will be more than happy to pay for there time in cash or beer currency goes in both!!
I actually sold mine a while ago when I "thought" I got out of the car scene. Speak to DVS Jes, I'm assuming he's a good honest tuner from what he shares on the forum.
If you ever go anything else like Adaptronic or Vipec you don't need an extra box to connect it up to a laptop. I got a mate that can get Adaptronic ECUs much cheaper than most stores.
BTW, just get a Nismo drop in fuel pump, less headache in the long run, less noise, no fuel starvation problems, no dying fuel pumps, no worrying about fake yumcha spec Walbros.
Bosch 040 will be fine and cheaper for your needs
Just bought one! thanks for the advice boys!
I can tune it if u want buddy. Will do u a competitive price too.
DVS JEZ you have PM
how come no one mentioned the deatchworks pump, theres a 300LP/H one thats under $200, if you decide to go for more power later you wont have to buy another pump,
When i got my power fc tuned at the same stage , they had to replace
*Coil packs
*Dump inadequate
* Fuel pump
* plugs
*Clutch
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
