Evenly dispersed block stiffness - same level of stiffness in the center and the shoulder for stronger grip and traction, prevents irregular wear. Uni-Directional V-shaped main groove enhances streamline form and also improves aquaplaning ability at high speeds. Wide angle grooves increase block stiffness, further enhancing tire's grip and traction. Engraved pattern name along the groove creates an exquisite product image. Sub-grooves on the shoulder disperse block stiffness, improving ride comfort, grip and traction. Complete block stiffness provides excellent lateral stability in cornering. The 595RS-R is beefed up by reinforced steel on the sidewall to promote the sharpest high speed cornering and fastest lap improvement.
Proven on the circuit, the 595RS-R is highly acclaimed and much demanded for drifting, sprinting and track-day applications. The sleek design and ultra high performance of the 595RS-R makes it the number one choice for those requiring a motorsport tire but with the assured standards of a street legal tire. Even DOT approved or E-Mark approved Federal competition tyres are designed and compounded for competition use only and are not intended for highway or road use.
595RS-R
215/45/17 $190EACH
225/45/17 $200EACH
235/45/17 $205EACH
235/40/17 $220EACH
255/40/17 $280EACH
225/40/18 $240EACH
235/40/18 $240EACH
245/35/18 $240EACH
255/35/18 $260EACH
265/35/18 $270EACH
285/30/18 $280EACH
We also stock all Federal other range of tyres..call for a quote
https://www.sau.com.au/forums/topic/398987-federal-r-s-r/
  • 1 month later...
  • Replies 46
  • 3 weeks later...
Mods please delete my post above.
Hadouken
Appologies - meant to post on the guys WTB thread. Pointed him to here previously to buy new from OTR.
I was checking here to put a price on my Federals in case he was interested.
Posted in his thread but couldn't see it so posted again. (accidently on wrong page :wacko: )
Sorry Ken.
https://www.sau.com.au/forums/topic/398987-federal-r-s-r/#findComment-6455351
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
