Hi guys,
I'm looking into buying a car that I came across the other day. Seller offer me $11,500. KMS = 90000
It is a 2 door manual.
1 year rego and no rwc.
What is the normal price for a R34 GT-T year 1999?
AND
Is R34 a good car to get? What is the common problem to look out for?
Edited by R33 Gts-T Sedan
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/
I am going to take it for a full engine and turbo checked by my mechanic.
I just wanted to know, do you think a 13 year old car engine is already tired?
Is an R34 engine reliable? I don't want to keep spending money to fix faults.
Need some advice before I buy it next week.
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/#findComment-6341965
how long is a piece of string? There is SO many things that will determine wether the engine is tired or not. . .has it been thrashed?, has it been serviced regularly?has the correct fuel been used in it? you have no way of knowing this, your mechanic can test the engine and determine by the results as to the condition of the engine
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/#findComment-6341975
btw, 90000km is a no go, pretty damn sure about that. ;)
or else it would fetch a bit more
Can you explain why 90k is a no go?
The paint, the interior and the body is actually in a very good condition. Full nismo bodykit. The spoiler looks really ugly tho.
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/#findComment-6341985
its a common thing for exchanged speedos or wound back speedos. so dont be surpised.
in a very rare case, it will be genuine. but rarely.
So dont believe the reading, see if the guy has auction papers or jap service receipts, log books etc...
that will give you a more accurate idea
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/#findComment-6341991
skyline engines are pretty tough, the most common things that fail in the car are: turbo, afm, coilpacks and o2 sensor.
Yes I changed my coilpacks to splitfire for my R33 GTS-T 2 years ago. Not sure bout afm and o2 sensor but the fuel economy is really bad. 250 to 300kms per full tank. Turbo is in good condition as it never been trashed.
I hope that R34 has a good engine and turbo. Will find out in a few days.
So how much does it cost to replace the turbo to the same one
OR
Remove the turbo if it fails.
Rough figures so I know what to expect.
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/#findComment-6341994
Thanks!!!! Will definitely ask for log books or anything that can prove the genuine kms.
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/#findComment-6341997
turbo is only available as a 2nd hand unit, and even then, they are getting old. find an equivalent size turbo to put on it, garrett or such.
wont be cheap, around the 1k mark for a same size turbo.
of for the same cash, get it rebuilt aka highflowed if it comes down to it. but that will create more lag. and lag is pretty bad as is on any skyline, dont want to increase it.
you can remove turbo and just get a "transfer" pipe from turbo to dump, but you will loose about 60% of your power and your car will run like shit. its never recommended to do that :D
coil packs, 400-600 depending on what your buying.
afm, round 200ish
o2 sensor is round 70 bucks
turbo dying can usually be heard, a high pitched whining is usually a give away, so is a heap of smoke coming out your exhaust under full throttle.
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/#findComment-6342021
How often will a turbo failure occur if I don't always boost it. I am a polite and average driver who does not boost if I'm not on a freeway. I will only be using the freeway mayb once a month to visit my friends. Can the turbo last 5 years? The previous owner don't often boost it as well. Engine and turbo in a good condition.
Will buy the car next week. Need to clarify this to remove any doubts that I have.
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/#findComment-6344036
how long is a piece of string? you have a r33 now. the r34 isn't much different. all the same principles apply to the r34 as to the r33. did you do research on what to look for before you bought your r33? if so, just do the same with the r34.
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/#findComment-6344167
Turbo can last forever.
Your mechanic's list will include compression test, running gear, suspension, oil sludge & burning, exhaust, coolant (for oil contaminant), leaks/seepage, irregular wear and tear and rail damage, hoses/clips, rust.
Your list will include running electrics, air cond, wear on steering wheel/bolster on driver's side/carpet/key entry to barrel/pedals, worn paint of panel bolts, doors dropping on opening, paintwork, rear wheel well, rust.
We want to know if it's had a hard life so that you don't have to cop the back end of it!
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/#findComment-6344174
As you have said, the car has NO rwc.
the engine and turbo are probably the least of your worries. id say it will be brakes and suspension, small leaks, and gaskets that will set you back money to get the vehicle up to road worthy condition.
i will never buy a car with no RWC when the seller said they 'dont have time to get a rwc' or 'it will pass road worthy with no problems'..
a car is the second most expensive thing you will buy/sell in your life. if you cant find an hour to get a rwc on a car that has 'no problems', than BUYER BEWARE
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/#findComment-6344219
i use the "no time" excuse because i simply don't have the time to take the car to a mechanic to get done. but i do take that into account when pricing the car as well. having said that, the cars i have sold "as is" have always then passed rwc's first time with no issues either. most of the stuff a car may fail a rwc for is easily checked yourself. as long as the tyres are good, there's no oil leaks, the brake pads are good and it drives well (no weird noises or vibrations) then there won't be much trouble with it passing a rwc. and besides, a car can be a complete lemon despite passing a rwc. they don't check actual condition of the engine, etc. just check that it is safe for the road. hence the fact that you can have a car pass a rwc that could be defected due to illegal mods.
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/#findComment-6344307
Thanks a lot guys. That was more than enough to answer my question. Car that comes with RWC does not mean anything. When I bought my R33, it comes with RWC but after I transfer the registration and take the car for a service, my mechanic told me there is an oil leak and several other problems that does not pass the RWC.
From then on I do not care bout RWC because I will rather spend $80 on a full RWC check, engine check and let my mechanic have a look at the car before I buy any car.
https://www.sau.com.au/forums/topic/399264-1999-r34-gt-t/#findComment-6344468
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
