  • Replies 42
Hrmm.. cyrus or the owner of the silver skyline.. I hope those are not aftermarket blue parkers you have.. coz if it is.. b prepared to get a fine if you get pulled over by a traffic officer.. the same wif the neons too
If you have no idea what I mean, I suggest you get a copy of the latest car modification guide and look for the word blue.
Just a lil word of warning. :rant:
Just a lil word of warning. :)
The silver one is mine... They are blue parkers...
The plan is to get me a defect for em...
Over 6 months with em so far and so far nada...
strutto is white and old like me, therefore he will be left alone..
hey.. not too bad there. Not even too far removed from my "artist impression" i did for you a while back. Sweet! Well i don't think anybody could mistake your skyline for any in Australia now, good stuff.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
