No May thread yet so thought i'd start one...
I recently got back from Hawaii.
Didn't get any FANTASTIC shots and not happy with the focus points on some but at the time i really couldn't tell.
That is volcanic smoke pumping out in the background on the big island
Kilauea Iki Overlook
Queen Lydia Liliuokalani Gardens
Beach panorama, it was crazy weather:
And a quick happy snap in the limo before my wedding, i love how the dresses look with the red of the limo interior.
Sorry that there's so many photos haha, none are exceptional but i think most are pretty cool in their own way
Edited by Passive
https://www.sau.com.au/forums/topic/399374-may-2012/
  • Replies 134
thought id take some pics of the port willunga jetty. not as good as the pros, but the kids had fun checking out the caves while we were there
my kids playing in the caves...
took a pic of our bus before we left
Edited by Jay019
https://www.sau.com.au/forums/topic/399374-may-2012/#findComment-6344496
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
