for sale is a reconditioned ca18det manual gearbox. i bought it a few months ago under the impression that it was an rb20 box, so it's no use to me. i haven't used it, but my mechanic has fully checked over it and checked every gear and has confirmed it is in very good working order.
pick up only from redlands/brisbane/logan area, wherever is easiest for buyer.
$500 o.n.o
will upload photos of it soon..
please text or email only, as i usually cannot answer calls;
[email protected] or 0431754784
Edited by yoitsnones
https://www.sau.com.au/forums/topic/399621-ca18det-gearbox-500/
  • 3 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
